What is this and why is it disconnected?
Old 15 Jul 2010, 05:42 pm
Default What is this and why is it disconnected?
I noticed the two wires, one red and one white, were not connected. It looks like they should be. What is the device that the red wire leads to? Should I connect these wires? Thanks.
Old 15 Jul 2010, 06:38 pm
Default Re: What is this and why is it disconnected?
It will be hard for anyone on this forum to tell you what it is because it didn't come with the PT. It's some sort of after market add-on that the previous owner added. Yes it does look like they go together to complete some sort of circuit but I wouldn't just hook them up until you find out what it goes to.
Try and trace the white wire inside the car. It probably goes through the firewall somewhere around the area of the hood release cable.That's the easiest place to put wires through from the inside to the engine compartment.
Old 15 Jul 2010, 07:48 pm
Thanks, I'll take a closer look and research more of what it could be.
Old 17 Jul 2010, 08:35 pm
That appears to be a siren for an aftermarket alarm.
Volume reduced when battery disconnected tom-t-rifik Sound and Security Forum 0 28 Jun 2004 05:25 pm
