2006 pt help
Old 19 Jul 2010, 12:03 pm
Exclamation 2006 pt help
hey everyone!!
well the problem was the switch i got that fixed for 200
but now im having problems with the gas pump or the electrical i dnt know
im getting tired of this car lol but i love it tho the car that is not the problem tehee!
the car is a 2006 touring edition.
if ur in the phoenix area and happen to know
Gary from certified mufler and auto parts
let me know he's a great mechanic but lost contact of him
Old 19 Jul 2010, 01:03 pm
Default Re: 2006 pt help
Your not giving us a lot of information to go on if you want help. As far as being in the Phoenix area, can't help.
Old 19 Jul 2010, 02:12 pm
Question Re: 2006 pt help
ok well its been having this problem every couple of months(each 6 months), ill be running good and then it would try to turn off, minutes later it turned off, next morning went to start it, right away it started, left 5 minutes to warm up and turned off again, now it doesn't start and it warns that i have no gas and i had 3/4 of gas.
Old 19 Jul 2010, 02:31 pm
Sounds like a pump/float issue inside the tank. Not sure if the PT has it, but might be shutting off because it thinks your out of gas and doesn't want the pump to drain dry. The pump depends on the gas to lubricate and cool it and can burn out if the tank becomes very low.
Maybe someone else will have another idea but sounds like it's going to need a good diagnostic by a mechanic.
Old 19 Jul 2010, 02:34 pm
chigger_ns's Avatar
The gas level is bad{sending unit. Very common problem with PTs}, and the stalling...it could need plugs and wires. They seem to love new plugs and wires.
2001 PT 5 speed Touring Edition
Eibach Pro Springs, Energy Suspension HyperFlex Master Kit bushings, 17" RTX Euro wheels, K&N drop in air filter, MotoMaster flat plate AGM battery, KYB GR2 shocks and struts, Booger standard shifter bushings, Ooogah horn.
Old 19 Jul 2010, 02:48 pm
It sounds more like a fuel pump to me. Often when fuel pumps begin to fail, they'll go out when they get hot, but work when they're cool. That's likely why you were able to start it first thing in the morning, but after allowing it to warm up, it would not restart.
A bad fuel level sender would not keep the engine from starting.
-Chris
Old 19 Jul 2010, 04:32 pm
Sounds like a fuel pump issue to me too. The fuel pump , fuel level sender and float are all one unit. If you check the PDC under the hood just above the air filter, you will see a fuel pump fuse and a fuel pump relay. Check both for tightness and to see any visable signs of failure. Also I seem to remember in the back of my mind that the ASD can be triggered by low fuel pressure to keep the engine from going lean. Check it too.
Jerry
Old 20 Jul 2010, 10:36 am
Thumbs up Re: 2006 pt help
so i just called a tow so they could take it to the mechanic i hope he gets it fixed right away, and i really appreciate all the answers from everyone i believe this is the best website, better then myspace jeje..ill get back to you guys when its fixed.
Tags
electrical, gas pump
2006 pt help fromphoenix General PT Cruiser Discussions 10 18 Jul 2010 02:22 pm
2006 PT GT KC2IFR General Turbo Discussions 1 05 Sep 2009 09:03 pm
2006 CHRYSLER PT CRUISER AUTOMATIC FACTORY WARRANTY, VERY CLEAN CAR (2006 CHRYSLER PT skylight craigslist 0 15 Jul 2007 01:10 am
My 2006 BeachBum General PT Cruiser Discussions 17 20 Jun 2007 07:25 am
2006 Spy Pic of PT Mean Green PT Cruiser News and Rumors 13 26 Oct 2004 07:29 pm
