Broken windshield cleaner hose connector
Old 20 Jul 2010, 12:23 pm
puddingmobile's Avatar
Default Broken windshield cleaner hose connector
Wasn't sure which section of the forum exactly this should go in. Move as necessary please.
One of the connectors that connects the windshield cleaner fluid hose to the squirty part (technical term) attached in the hood broke. I only have one working windshield cleaner squirter now--luckily it's the drivers' side.
Where can I get a replacement connector, is it something I need to get from a dealer? Is it something I can easily attach myself?
Thanks for any and all help.
Old 20 Jul 2010, 12:51 pm
Default Re: Broken windshield cleaner hose connector
This part of the forum is good enough.
Your technical terms are a little confusing about what part actually broke but if you can get it off, take it to any car parts store and see if they have a replacement. They probably do. If the part you need doesn't come off, just tell the clerk that it's part of the windshield washer system and they should be able to direct you to where they keep replacement parts.
P.S. thanks for adding your input to the person looking for a yellow convertible.
Old 20 Jul 2010, 12:52 pm
As I said, it's the connector that broke. The connector that attaches the hose to the part in the hood where the water comes out. My hose no longer attaches to the hood.
Old 20 Jul 2010, 12:57 pm
That "connector" might be part of the squirter itself so you might have to replace the squirter. They usually come in pairs, at the same store I told you about.
I replaced both of mine with lighted squirters so I can't go out and look at what your talking about.
Old 20 Jul 2010, 01:15 pm
Same thing happened on my daughter's - only both squirters died...
Hardest part is getting the hood blanket clips off - I used a flat screwdriver and needle-nose pliers.
I took out old nozzles (they snap in, depress clips and push out), and be sure to get any old plasic ought of the hose.
Buy any LED washer nozzles - just didn't hook up the lights on my daughter's.... The new one "bolt" is (a nut on underside of hood) and fit and work fine.
Old 20 Jul 2010, 02:48 pm
Be ware if you're going to buy LED washer nozzels that they're usually not street legal, so I wouldn't have them lit while you're driving.
-Chris
DLC/OBD II Connector wiring pwhittle Tech & Performance Forum 1 02 Apr 2010 01:41 pm
What's the connector pinout for 2006 alt? mluckey General PT Cruiser Discussions 2 27 Aug 2008 07:28 pm
vacuum t-connector location. anyone have a pic? pppt03turbo Tech & Performance Forum 0 15 Oct 2007 03:49 pm
ipod connector for 03 GT strangelove General Turbo Discussions 13 02 Mar 2006 06:48 am
ipod connector Neo Ion strangelove Sound and Security Forum 2 05 Nov 2005 05:21 am
