my 03 Limited
Old 22 Jul 2010, 12:15 am
edb edb is offline
Default my 03 Limited
Hi, everybody:
I am a new cruiser. Just bought a 03 Limited with 18,000 miles last week. I took it to a 500 miles round trip this week after a fresh oil change (Mobile1 synthetic and K&N oil filter). It seems that I can get 24mpg on highway, <20mpg in town. Both numbers are lower than the EPA numbers, I am a bit disappointed. Is there anything I can do to get better gas mileage? I am planning on a K&N air filter and spark plug replacement.
Another issue I had is the body vibration. At any speed, the car body is vibrating, I can feel it through my feet on the floor. At low speed, it's barely noticeable, but above 50mph, the vibration is quite clear. At this point, I suspect the muffler causes the problem. Could it be something else?
Thanks.
Old 22 Jul 2010, 03:44 am
chigger_ns's Avatar
Default Re: my 03 Limited
Could be an engine torque strut out of place. They are adjustable.
2001 PT 5 speed Touring Edition
Eibach Pro Springs, Energy Suspension HyperFlex Master Kit bushings, 17" RTX Euro wheels, K&N drop in air filter, MotoMaster flat plate AGM battery, KYB GR2 shocks and struts, Booger standard shifter bushings, Ooogah horn.
Old 22 Jul 2010, 06:28 am
Johns Steel Blue's Avatar
Originally Posted by edb View Post
Hi, everybody:
Thanks.
24MPG is nothing to complain about. Remember, the Cruiser has the aerodynamics of a brick and is a heavy car for it's size.
John
People say I have a drinking problem. I Drink... I Get Drunk... I Fall Down... No problem! ! !
Old 22 Jul 2010, 07:19 am
Dino's Avatar
Get rid of the stock wires also, as far as the vibration goes how are the tires and rims looking?
Old 22 Jul 2010, 12:48 pm
edb edb is offline
I fill up the tank today, and did some calculation. It turns out that it only manages 22.3mpg on 100% highway driving. I have a Chevy HHR, it also has a 2.4L engine, but I can easily get 30mpg on highway. These two cars have pretty much the same curb weight.
Old 22 Jul 2010, 03:09 pm
edb edb is offline
Are there any special brand of wires I should buy? Or any good wires are fine?
The front tires are Goodyear, the rear are Firestone and have less wear. I think the problem is not the tires or rims. I had unbalanced rims before and certainly know how it feels.
BTW, the gas pedal is also vibrating with the body, does that suggest something?
Old 22 Jul 2010, 06:09 pm
edb, the vibration suggests that you should replace the plugs and wires. since you have an 03 and with 18,000 miles I'm sure that the plugs have not been changed. That would be fine if you had a newer PT, but in 04 Chrysler put out a TSB to change the gaps on the plugs to 0.040 instead of 0.050 that were on all the PTs until then. You could get by just changeing the gap on the original plugs, but most of the owners I know went ahead and changed the plugs when they had the opportunity. I'd use the stock coppers on yours. They should be fine for the type of driving you do.
I would change the wires at the same time. You could use the "blue" (hp) Chrysler wires or most other "quality" aftermarket wires. MSD, Magnacore, Taylor, Granatelli, etc., etc. would do fine. I don't recommend the stock Chrysler wires.
Also check your air filter.
These things should help the mileage and the vibration in one swell foop.
Jerry
Old 22 Jul 2010, 06:25 pm
Edb, more concerning the mileage. I know you're obviously aware that they are both 2.4 motors, but also obviously not the same 2.4 motors. The HHR was aimed more at mileage when it was designed. Also tranny gearing comes into play where mileage is concerned. The HHRs are geared for mileage not performance. A stock N/A PT will put it on an HHR EVERY time at the drag strip. It's a matter of record over at The Crew. Also our PTs weigh in at about 3200. The HHRs are about 3000 if I remember right. That's like hauling another person around with you everywhere you go.
Jerry
Old 22 Jul 2010, 06:35 pm
Edb, also, also, concerning the higher speed part of the vibration really, really sounds like an either out of balance wheel or a tire separation.
You said it might be the muffler causing that. Could you explain that please.
Could you post a picture of your cruiser please?
Jerry
Old 22 Jul 2010, 07:49 pm
edb edb is offline
Jerry
Hi Jerry:
Thank you for replying my post.
I don't have a digital camera at hand right now, I will upload a pic later.
I first suspected it was the muffler, but changed mind.
Limited to 3000rpm thisispops Tech & Performance Forum 1 01 Mar 2009 04:12 pm
where to buy on 04 limited rim?? bobs turbo pt Wheels, Tires, Suspension 2 22 Nov 2005 10:12 pm
2004 PT LIMITED 1MEAN PT General Turbo Discussions 10 30 Jun 2004 10:12 am
Is this car a Limited or DreamCruiser? wheresgrant General PT Cruiser Discussions 13 05 Jun 2004 09:19 pm
