Need help
Old 26 Jul 2010, 07:17 pm
Default Need help
Hello everyone.
I have a 2005 Cruiser with under 17,000 miles.
I have a Malfunction Indicator Light on. I ran the "trick" with the ignition switch, as per a post here, and got a code #.
I have looked through several posts, but need a list of the code #s, and what they indicate.
Thanks for any help you can provide.
Old 26 Jul 2010, 07:45 pm
Default Re: Need help
Sure, here ya go......
Error Codes
Come back if you need more help.
Old 26 Jul 2010, 08:40 pm
Cool Re: Need help
Thank you very much!
Old 26 Jul 2010, 09:05 pm
Okay, I just went out, and triple checked.
I am getting the code P 0456.
Any idea what that means?
Old 27 Jul 2010, 01:43 am
P0456 is a small evap leak, or small vacuum leak. Some people on here might suggest to make sure your gas cap is loose, but there's a code specifically for a loose gas cap, which you don't have.
Check all your rubber vacuum lines in the engine. Having such low mileage on a 5 year old car, it comes as no surprise that a few vacuum lines might be a little dried out and brittle, allowing unmetered air into the engine.
-Chris
Old 27 Jul 2010, 10:39 am
Thanks Chris.
Old 14 Aug 2010, 02:57 pm
Cool Re: Need help
I finally went out today to work on the Cruiser. It was cool compared to how hot it has been in this area.
I have trouble with the heat because I have MS. I hate having it, but after 12 years, I still walk and still drive, so I can't complain.
I am an aircooled VW guy. I have a '73 Karmann Ghia which is my playtoy. Turboed, fuel injected, and I built it from the ground up.
But the PT Cruiser is all new to me, and I was lost, until I found this forum.
I have it running well now, no engine light, and I want to thank everyone who passed on all the good information.
You guys have a great weekend!!!
Old 14 Aug 2010, 07:57 pm
Dino's Avatar
So what did you find?
I hear you with the heat and MS one of my best friends has it and the heat hurts him bad.
Old 14 Aug 2010, 10:22 pm
Cool Re: Need help
Hi Dino. I did several things.
I had a locking gas cap which had seen it's better days, so I put the original cap back on, which had hardly been used.
Then I put a new air filter on, and cleaned the small foam piece that was under the air filter.
While I was doing all this, I had the - battery cable undone.
I put it all back together, started it up, and the engine light was off. I also checked all the hoses and electrical connections, and everything looked to be in good shape.
It's good to have my car back the way it's supposed to be!
Old 14 Aug 2010, 10:51 pm
Dino's Avatar
Excellent
