Power Windows, AC/Heat Fan don't work
Old 28 Jul 2010, 12:30 pm
Default Power Windows, AC/Heat Fan don't work
Hello!
I have a 2001 PT Cruiser, and a couple of weeks ago the power windows and the heating/cooling fan in the dash stopped working. The Air Bag light is also on, so I think the sensor is affected by whatever the problem is. They all have separate fuses, which appear to be good. I suspect it's a relay, but can't locate one for those systems.
Any suggestions?
My thanks for any help you can provide!
-Patrick
Old 29 Jul 2010, 03:27 pm
Default Re: Power Windows, AC/Heat Fan don't work
Patrick,
I was hoping one of the mechanics would come along and have a suggestion because it sure sounds strange that all those separate things are wrong at the same time. I know of no relay that ties them together. You might just have to have a mechanic with a scanner see if he can find the problem.
Old 30 Jul 2010, 07:19 am
Hi Crewzin!
I was hoping someone would too. Looks like I'll be taking her to the shop.
Thanks!
-Patrick
Old 28 Jun 2012, 09:26 am
Hello Patrick,
Did you find the answer to this issue? Ours just did this exact same thing this week. Wife started it up and all the windows wouldn't work, Air bag light is on and the inside blower fan does not work. Checked all fuses. NAPA says theres a 4 prong multi relay somewhere that could be the issue. What did you find was the culprit with yours?
Thanks
Retrofn
Any suggestions?
-Patrick[/QUOTE]
Old 28 Jun 2012, 02:17 pm
Check fuse # 3 (40 amp) in the power distribution center (PDC) under the hood. It is a common feed to the fuses and circuit breaker for all three systems that you mentioned.
Originally Posted by Retrofn View Post
...Ours just did this exact same thing this week. Wife started it up and all the windows wouldn't work, Air bag light is on and the inside blower fan does not work. Checked all fuses. ...
Retrofn
Old 02 Jul 2012, 09:16 am
I rechecked this fuse and even replaced it with one of the others. No luck so the hunt goes on.
Old 09 Jul 2012, 12:18 pm
Default Power windows quit - Ignition Switch
Hooray, We had to bring the PT in to find this one. Our mechanic spent a few hours on diagonistics. The issue was a $50.00 ignition switch!. Even though the car would run it wasn't giving power to all systems. He also saw a draing to the air bag. Replaced this switch and bingo, alls well.
Old 17 Jul 2017, 06:34 am
I know your post is quite old, but wondered if you remember if it was the actual ignition switch that holds key or was it the ignition starter switch module. Thanks
Old 17 Jul 2017, 07:01 am
rckstein's Avatar
Welcome to the forum
The OP hasn't been back on the forum since 08/10.
When you get a chance, please go to https://www.dodge.com/webselfservice/dodge/index.html and create an intro thread telling us a little about yourself and your PT
Old 17 Jul 2017, 07:06 am
Most likely the ignition tumbler switch. There's a piece on the end of them that breaks off from time to time. Cheap pot metal.
Tags
hvac fan don't work, power windows
Power locks don't work CruisinUehzA Tech & Performance Forum 14 10 Mar 2017 07:28 am
Power Locks and Headlights Dont Work Pt_SRT Tech & Performance Forum 2 22 Apr 2010 06:33 pm
Power mirrors don't work '03 gt eastsidepool General Turbo Discussions 5 22 Apr 2010 09:08 am
Windows and Fan Won't Work CarolTurner888 General PT Cruiser Discussions 0 09 Sep 2007 07:17 pm
When do YOUR windows work? jbrown1977 General Turbo Discussions 4 18 May 2004 12:32 pm
