"STUCK"
Old 02 Aug 2010, 08:45 pm
Unhappy "STUCK"
Please help..I have an 02 pt cruiser that had intermitent stalling then went dead at an intersection. Had it towed/ ran the diagnostic scan code:" p0340 cam shaft position sensor circuit" came up...so i replaced the sensor..no start..checked the spark plugs with a tester they were pulsing..replaced the battery...heard the fuel pump engage..checked the fuel check valve stem..it sprayed gas out so i checked the air filter...took it off...i jacked up the car and looked at the crankshaft sensor underneath and it was dirty so i cleaned it..still no start....checked the pins on the connection harness that goes into the cmp sensor with an ohmmeter and they registered they were working..i checked the condition of the harness..looked ok...any ideas ...appreciate the help..Brian
Old 02 Aug 2010, 09:36 pm
Default Re: "STUCK"
have you ever did the timming belt , it might be broken
Old 02 Aug 2010, 09:59 pm
Dino's Avatar
Default Re: "STUCK"
How many miles? Like LNBNDN said could be the belt.
Old 02 Aug 2010, 11:26 pm
xwing777's Avatar
Default Re: "STUCK"
Check the ground wires and clean them. Also many have reported problems with aftermarket sensors, so use factory if you didnt.
Part number for "PT" door emblems on 2008 Dream Cruiser 5 gpr75 General PT Cruiser Discussions 6 16 Jul 2010 12:15 pm
HVAC stuck on "outside air" bobdole369 Tech & Performance Forum 3 18 Sep 2009 02:10 pm
Engine overheating, Stuck in "Limp mode" showing codes 0188,1490,&1495 Manny Tech & Performance Forum 4 08 Apr 2009 05:39 am
