Thinking of purchasing a GT.
Old 03 Aug 2010, 01:01 pm
RaineMan's Avatar
Default Thinking of purchasing a GT.
Hey all.
A dealer in my area has a 2003 GT automatic with extremely low miles.
Anything in particular I should be on the look-out for when I go see it?
Thanks!
Old 03 Aug 2010, 01:18 pm
Default Re: Thinking of purchasing a GT.
You want to get a good look at the front suspension to included the front wheel bearings. You want to drive it to see if it has all the boost it should have. You want to let it sit, running at idle, for about 15 minutes and keep an eye on the temperature guage. If should go anywhere past the half way mark.
Old 03 Aug 2010, 01:31 pm
RaineMan's Avatar
Exactly how much boost should I be looking for? I've read some specs on these things but I didn't see stock boost pressure listed anywhere.
Old 03 Aug 2010, 01:40 pm
Sorry, maybe I shouldn't have said boost unless one of the Turbo owners comes in and can say exact numbers. Look for good fast acceleration from get-go to almost red line.
Also when your checking out the idle time and temperature guage, make sure it idle nice and smooth the whole time.
Old 03 Aug 2010, 04:10 pm
With low miles, you should be okay - if you get it, put synthetic oil in it from now on.
Look for smell that might indicate flood damage...
Old 03 Aug 2010, 07:02 pm
03GTCruiser's Avatar
When you test drive it, it should put you back in the seat nicely. I would switch traction control off if you plan to buy it as with it on it will rattle your teeth out from wheel hop.
I've had my 03 GT autostick for 2 years now and no major issues not from my doing. 1 maintenance issue from before my ownership that was fixed the first week
Then there was my motor mount/axle fiasco where I rompedmon the car without turning traction control off.
I broke a motor mount which slammed the engine into the passenger side axle and busted it.
Sold 2003 Pt Cruiser GT Autostick. Sold
Now a slow 2009 Pontiac vibe 2.4l 5-speed.
http://www.ptcruiserlinks.com/forum/image.php?type=sigpic&userid=9656&dateline=1247691  818
227 HP and 281 TQ
new best of 14.56 1/4 mile on 7/25/12 still using the canned tune from my diablosport predator.
*Stage 1, DSP w/93 canned tune, 3" o2 housing, 3" FWDPerformance downpipe with cutout. Bwoody solid mounts. AMX1397 TTAB with K&n drop in filter and airbox mod. AMX1397 lower pipe and AMX1397 uppipe with HKS BOV
* stock nsrt rims powdercoated black, chrome pillars.
* 3 gauge pod w/ aem wideband, Autometer ultralite oil pressure and 30/30 boost, Mopar 8" sub.*
Old 03 Aug 2010, 09:00 pm
mjb457's Avatar
Ok I have 2 PT's both 2003,, one is a GT 43k miles very quick -a blast to drive.(Diablo Prediator Tune,drop in filter other PT- non turbo 83k miles,,big difference in power,,but as daily driver fine.How many miles? any records? Get under it,,pay someone to check it out- worth it if ok//price? If its ok you will love the GT..good luck..MJB
Old 04 Aug 2010, 10:17 am
RaineMan's Avatar
I haven't actually been out to the lot to see it yet... just found it on the internet.
It shows about 27,000 miles... which is insanely low for a 7 year old car. Must have been someone's summer car. From the pics I've seen the engine bay is stock and unmolested, which is good as I am wary of buying modded tuner cars.
The dealer is asking $8500 for it, which I think is a little high but if the vehicle is as clean as they claim and the mileage is accurate I don't mind paying more. To find anything with a turbo and low miles for under $10k is unheard of as it is.
Old 04 Aug 2010, 02:21 pm
nevinsrt's Avatar
you kidding me thats a good deal for 27k mi. im looking at an 03 with 100k mi for $7400 and a second 03 with 60k mi for $8000, both are all stock and very clean. just go test drive it. these cars dont come stock with boost gauges so if it puts you in the seat from 2500rpms up to 5500rpms then your good.
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
I'm not selling, I'm purchasing from a Dealer anything I should look out for? Shais General PT Cruiser Discussions 13 27 Feb 2010 11:53 pm
Another "considering purchasing" thread from a dang newbie poster kd4pbs General PT Cruiser Discussions 8 30 Dec 2009 05:26 pm
purchasing first PT adomeit PT Cruiser Convertible Forum 6 23 Nov 2007 05:50 pm
Considering purchasing new Pt - But Concerned? emhg89 General PT Cruiser Discussions 9 04 Aug 2007 02:02 pm
Worried about purchasing PT convertible.... Sas PT Cruiser Convertible Forum 0 11 Aug 2005 02:02 pm
