Check Engine Light on
Old 04 Aug 2010, 12:13 pm
Default Check Engine Light on
Hey all, I went out on lunch started my car up and everything was fine. My car has a Escort radar system and the speaker was unhooked so i had to pull the gauges to get to the wires. I plug my gauges back in and whammo my check engine light is on. Any idea as to why this would happen or how can i check to see what code its throwing...
Old 04 Aug 2010, 12:16 pm
Default Re: Check Engine Light on
How to retrieve fault codes.
Old 04 Aug 2010, 12:22 pm
Ok got the codes now where can i get the code list...
I got u0155 and 110c
Old 04 Aug 2010, 12:25 pm
Quickest is type in P____ code in google
Old 04 Aug 2010, 12:28 pm
Ok so both of them have something to do with the calibration of the cluster or a memory error in the cluster I wonder if I just unplugg the battery and reset the comp if that would help.
Old 04 Aug 2010, 12:31 pm
You didn't find the right error codes - you got console codes, not engine codes.
You didn't do the "key trick"...
Old 04 Aug 2010, 12:36 pm
yea i turned it three times it gave me those 2 codes and then said done.... It would be along the guidelines of what I was doing I removed the cluster.
Old 04 Aug 2010, 03:46 pm
chris15's Avatar
The first code is legit.
PU0155 - NO BUS
Basically the car can't communicate with your gauge cluster. Quick Googling suggests that you'd need to take it to a dealer or find someone with a DRB3 scan tool to reset the cluster.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Old 04 Aug 2010, 09:09 pm
Thanks for looking it up. I checked with a friend at a dealer he said if you unplug the cluster while the car is on and then plug it back in it will happen with those codes. He told me to pull the negative cable and wait 10 min, So I did and light is off.
Old 04 Aug 2010, 09:47 pm
chris15's Avatar
Yep, that'd probably do it. Hopefully it stays off.
Edit: I didn't realize that you had unplugged/plugged in the cluster while the car was on-- probably would've been a lot easier to diagnose had I not assumed the car was off. :P
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Check Engine Light - Help! loki547 Tech & Performance Forum 11 11 Mar 2012 11:38 pm
Check Engine Light Yellow PT General PT Cruiser Discussions 6 23 Jul 2010 02:57 pm
MIL (check engine light) without a DTC golfkell General PT Cruiser Discussions 5 09 Mar 2010 11:20 am
CHECK ENGINE LIGHT MEXICANPT Stage Turbo Kits 3 08 Aug 2003 11:13 am
