K&N air filter bad for engine?
Old 05 Aug 2010, 09:40 pm
edb edb is offline
Default K&N air filter bad for engine?
My 03 Limited is currently running on K&N oil and air filters.
I bought the air filter from Amazon.com for 36.16, free shipping. One of my friends told me the K&N filter allows greater air flow rate simply because it filters less, and it could be actually bad for the engine.
The old filter is a FRAM, I looked at it against light and can't see through; but I can clearly see through the K&N filter.
I am a bit concerned, is it really bad for engine?
Old 05 Aug 2010, 10:56 pm
Dino's Avatar
Default Re: K&N air filter bad for engine?
I wouldn't worry about it all that much, the amount of expensive engines running around with high quality aftermarket filters is huge and if their was a problem it would be known. It's true though it does let in more airflow with in-turn could have a minuscule amount of dirt in it. I've had mine a Airaid CAI for a while and no issues except a better running PT.
Old 05 Aug 2010, 11:18 pm
I have used K&N air filters for years and never had any problems. There is also spray on oil for K&N air filters and that actually helps to catch more fine particles than a paper-based air filter. The reason they flow better is because of a finer mesh than other air filters. Believe me, a K&N does provide better throttle response over a regular air filter - especially with turbos.
Mike
06 PT Cruiser LE Turbo Lite (Green Onyx Pearl) - K&N drop-in air filter, MSD wires, iridium plugs, chrome package, leather, sunroof, uConnect
04 PT Cruiser Base Model 5 spd (Cool Vanilla) - K&N drop-in air filter, Flame Ball light-up shift knob, MB 16" rims with Faulkens
86 Dodge Daytona Turbo Z CS - 2.2L Chrysler I4 bored .030 over, 89 SOHC fast-burn swirl head with roller cam and rockers polished and ported with 1mm oversized valves, full 2.5" exhaust from swingvalve back with Dynomax Super Turbo Muffler, Chrysler A413 Torqueflight 3 spd auto trans rebuilt with Alto high performance clutch packs and Cheetah RMVB, FWD Performance 15psi calibration, Mopar 804 Injectors, custom 3" intake with modified log manifold for intercooling, grainger valve manual boost controller, rebuilt Garrett turbocharger precision balanced
Old 06 Aug 2010, 01:18 pm
I have one on every vehicle, to include my airplane ($30,000 engine) - with no problems.
2005 Limited Turbo-Lite, auto in Cool Vanilla
Old 06 Aug 2010, 01:25 pm
edb edb is offline
Thanks for everybody's reply. The K&N fiter is now in my PT. I will see I can bet better gas mileage as many users did.
Old 06 Aug 2010, 04:09 pm
Another opinion:
Air Filtration Test
Old 06 Aug 2010, 05:57 pm
CreepyPT's Avatar
Send a message via Yahoo to CreepyPT
It's not just the filter that filters the air, it's the oil in the filter too. Bought the air filter and the maintainance kit at the same time.
Old 07 Aug 2010, 03:55 pm
Your friend should stop talking about cars. What he said is not true at all.
The reason they flow better is because they're made out of a gauze material instead of paper, which simply allows for better air flow.
-Chris
Old 07 Aug 2010, 08:04 pm
YoungCruiserrr's Avatar
Send a message via AIM to YoungCruiserrr
can i see your airplane?
2005 Brilliant Black
PT Cruiser Touring Edition
34,000 Miles.
Old 07 Aug 2010, 10:01 pm
marvinsc's Avatar
Fact: Air is a necessity for internal combustion to happen (filtered air is preferable)
Fact: K&N has been around for years and has a fine reputation.
Fact: I ran a K&N on our first PT for over 70,000 miles with no issues at all.
Fact: If filtration restricts air flow too much, engine performance will suffer.
Suspected fact: Your friend is misinformed
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Can 2001 Engine be replaced with Newer Engine harleysforfun General PT Cruiser Discussions 1 07 Aug 2009 01:38 pm
Issue With my 2001 PT Air Filter/Fuel Filter/Tranny Rekoj Tech & Performance Forum 7 10 Jul 2009 12:27 am
Engine lurcing + engine lite come up on 05 GT Roadmaster General Turbo Discussions 11 18 Apr 2009 01:10 am
N/A Base Engine vs Turbo Engine Kirby General Turbo Discussions 7 02 Oct 2003 01:42 am
