2005 pt timing belt
Old 07 Aug 2010, 11:41 am
Default 2005 pt timing belt
hey all :
well been a guest at this site for a year or so have found wealth of knowledge so thanks.. but to the point i have a 2005 pt and have diagnose it down to timing belt or tension pully .. peak through the hole in timing cover to see that with new starter (another story) that when cranked the cam gears do not turn.
i am now with car on stands in my back yard digging into the car i am taking pic's along the way will post more as i do it just have seen a lot of post on this subject..
i am just a shade tree mechanic self taught by necessity..
with common hand tools..
we live we learn..
Old 07 Aug 2010, 12:25 pm
Default Re: 2005 pt timing belt
Welcome to the forum, since you've only been lurking on the side. Good luck with your project. Hopefully you've seen all the problems with changing the timing belt that people have had that didn't have too much experience with major mechanical work. You've also probably seen that we always recommend to change the water pump also at the same time because it wears out just like the belt and you have to go through the same procedure to change the pump as you do in changing the belt. Might as well do them together and not worry about either for another 100,000 miles.
Be careful when lining up the gears as many pro and non-pro have done it wrong and had the dreaded ruff idle and and to do it all over again.
I'm not trying to scare you, just letting you know it's not an easy job as you might have found out from reading the forum. Again, good luck. Let us know how it went.
Old 07 Aug 2010, 01:36 pm
Dino's Avatar
Good Luck. Look forward to seeing the pictures
Old 07 Aug 2010, 06:09 pm
thanks for the advice yes i plan on replacing the water pump and all belts while im in it and have a print out that shows the timing mark line ups so if the car gods with me that will work out well
got to the head pulley and broke my mid size pulley puller and had to go find a beast to use but no good, got someone on way to get a torch to add a little heat so see how that goes ill get a few where at photos later on at least ill have some step by step photos might help the next person out
Old 08 Aug 2010, 08:34 am
Go to your nearest auto parts store and take advantage of the tools you can borrow. I borrowed the harmonic balanced pulley puller from Advanced Auto and it worked really well.
Old 08 Aug 2010, 09:27 am
Dino's Avatar
Yes this is excellent advice, I always forget Advance does this
timing belt Thomas1 Tech & Performance Forum 20 21 Jul 2012 09:06 am
Belt change help - Not timing belt skfloyd Tech & Performance Forum 2 23 Apr 2010 11:23 am
timing belt skydj1 General PT Cruiser Discussions 5 07 Apr 2010 02:40 pm
Could it be the timing belt? mbmouse Tech & Performance Forum 4 12 Jan 2009 09:01 pm
Timing Belt shaynebooth Tech & Performance Forum 2 31 Jul 2008 02:54 pm
