Transmission Pan Help
Old 07 Aug 2010, 07:43 pm
Default Transmission Pan Help
My Transmission Pan is leaking. This has only started after I replaced the fluid. I tried replacing the gasket afterward but it didn't seem to help. Also 3 of the screws just seem to be turning in their hole. Are some of these screws longer than others? They all appeared to be the same. I took the pan off and checked the gasket... it is in place fine ... i have tried different screws (from other parts of the pan) and it doesn't seem to help. Any ideas?
Old 07 Aug 2010, 07:54 pm
Default Re: Transmission Pan Help
It's an automatic transmission ... I know my other car is a manual and just uses gear oil, but if it wasn't apparent figured I'd mention it.
2002 41TE Trans
Old 07 Aug 2010, 09:21 pm
i just did my trans fluid last weekend and the bolts are all the same size .sounds like you have some bolts that are stripped out . who are going to have to get the ones that are stripped out rethreaded and did you use any gasket sealant . you should have used gasket sealant also
Old 07 Aug 2010, 09:31 pm
bolts aren't stripped. the threads are fine and they'll work in other holes as well as screw in the hole without the pan there with no problem. do you recommend a gasket sealant ?
Old 07 Aug 2010, 10:02 pm
yes you can put a small bead of sealant on the pan and than put some on top of the gasket i myself use the clear silicone . works good we use clear at work good luck................
Old 07 Aug 2010, 10:05 pm
the threads in the trans could be stripped out and not the bolts ... I am a mechanic for 27 years on big rigs
Old 07 Aug 2010, 10:14 pm
i screwed it into the trans without the pan and it went in fine and held, maybe my gasket is crooked? i took everything off several times trying to remedy it ...
Old 07 Aug 2010, 10:25 pm
i would than take pan back off and make sure gasket is not torn ,and make sure pan is clean and bottom of trans is clean , also you do not have to use a gasket if its torn , on my pt it did not have a gasket it only had sealant put on hope this helps let me now
Old 07 Aug 2010, 10:27 pm
it's just one corner that's not screwing it... should i try it with no gasket or maybe remove the gasket from that part and use sealant? or is that a terrible idea?
Old 07 Aug 2010, 10:34 pm
sounds like the gasket is not lining up .do you have it faceing the right way
transmission lotta Tech & Performance Forum 6 29 Sep 2005 08:44 pm
transmission metz General PT Cruiser Discussions 5 15 Feb 2005 01:40 am
New Transmission Red GT General PT Cruiser Discussions 3 02 Nov 2004 08:55 am
Transmission Went Mean Green General PT Cruiser Discussions 8 16 Oct 2004 11:49 am
transmission fyrebuster General PT Cruiser Discussions 5 28 Jul 2003 01:11 am
