Tie Rod End Issue during replacement
Old 08 Aug 2010, 08:06 pm
Default Tie Rod End Issue during replacement
I was replacing my tie rod ends tonight and the drivers side went pretty smooth but when I got to the passenger side I ran into a problem.
I got the jam nut loose and unscrewed the tie rod end. I put the new end on and couldn't get the jam nut tight against the tie rod end. Normally, I know that using heat would be the best option to move the jam nut (which I do not have.) I know I need to get the car aligned now after doing this. Should I mess with it anymore or just take the car to get it aligned and let the person doing it worry about it?
Would it be safe to drive maybe a mile or two?
They would be obligated to make sure everything was tight right?
On a side note, the drivers side tie rod end was the source of my last clunk from the front end...
HID issue CYCLONE_06 Tech & Performance Forum 0 16 Apr 2009 08:00 pm
02 PT issue jparksp Tech & Performance Forum 4 18 Feb 2009 12:11 am
A/C issue. hermtm2 General PT Cruiser Discussions 9 26 Jul 2008 08:40 pm
the oil issue zoned Tech & Performance Forum 3 17 Nov 2004 09:47 am
