Auto Transmission...junk?
Old 10 Aug 2010, 11:57 am
Default Auto Transmission...junk?
I recently bought an 08 PT cruiser touring edition with 24K miles. Looks & runs just like new. I keep hearing what a piece of junk the Auto Transmission is. Is this true or is it about average ? Comments please...
Thanks,
Roger
Old 10 Aug 2010, 12:06 pm
Default Re: Auto Transmission...junk?
There does seem to be a lot of deaths of Autos...
Best thing to do - every 50,000 miles - find a place with a flushing machine and have all the fluid flushed out and refilled. Be sure they only use ATF + 4.
Old 10 Aug 2010, 12:07 pm
Roger,
Who told you that, a Fix Or Repair Daily guy probably.
There's loads of us with over 100,000 miles without a problem at all with the transaxle. Now, it your going to challenge the ricers from stop light to stop light, it won't last long ....it's CRUISER. Drive normal, change the fluid with ATF+4 when needed and it will last.
Old 10 Aug 2010, 12:09 pm
You only beat me by a minute this time Don.
Old 10 Aug 2010, 12:13 pm
I'll put my feet up for a bit...
Old 10 Aug 2010, 01:24 pm
Thanks for the replys..I have read on several forums how the PT's transaxel has given readers lots of problems, plus my neighbor had to replace his. I guess when you buy a new (new to me) car, you automatically start looking for potential problems.
Roger
Old 10 Aug 2010, 02:04 pm
Dino's Avatar
Roger
It's mostly the turbo PT's with the auto, if you boost in 4th gear the trans goes bye bye
Old 10 Aug 2010, 07:30 pm
I can't think of a single transmission we've had to replace at our dealership. Maybe 1 or 2 in the entire 10 year run of the PT. The bottom line is, if you take care of the tranny it can outlast the car. The vast majority of transmission failures can be directly or indirectly related to never flushing/replacing the fluid.
I wouldn't worry about yours for a while, though, because you still have warranty if it's an '08 with only 24k miles.
-Chris
Old 10 Aug 2010, 08:20 pm
VNT's Avatar
VNT VNT is offline
My advice would be to do pan drop and filter change every 30 K.
You could also add a magnefine external filter on one of the cooler lines. I would put a B&M bulkhead fitting/drain on the pan when you do the first change and then that would allow you to drain it in the future without the mess when you drop the pan or just change the external filter and drain and refill.
Dont bring it to bubbas or schlepp boys because they wont give a rats as$ and will probably use the wrong fluid. I would do it myself and after changing the filter and pan and refill do a cooler line flush.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 10 Aug 2010, 08:26 pm
Glad I posted this question..Seems like the only thing I was hearing was negative. Thanks again,
Roger
PT A/S Auto Transmission Shifter bmeador55 General PT Cruiser Discussions 0 09 Aug 2010 05:41 pm
Worried about auto transmission DIYPTGUY Tech & Performance Forum 23 23 Dec 2009 02:18 am
transmission(auto) interchagability bbtazhny Tech & Performance Forum 1 17 Sep 2007 01:13 pm
Rebuild Auto Transmission strangelove Tech & Performance Forum 9 30 Oct 2006 09:48 am
Auto. Transmission Question DennisB Tech & Performance Forum 5 08 Mar 2003 02:27 am
