Left front wheel squeaks...
Old 10 Aug 2010, 11:48 pm
Unhappy Left front wheel squeaks...
Hi,
I am not sure what's going on here... When I drive, I hear a noticeable squeak for each revolution of the wheel on the left (driver's) front side. It stops when I brake, and when I get to highway speed, I don't really notice it anymore.
It's only this wheel. I just got an alignment done... could that be the cause?
Any advice would be much appreciated!
Thanks!!
Old 11 Aug 2010, 12:31 am
Default Re: Left front wheel squeaks...
are your rotors painted,
, i had the same problem, forever,
it was from the painted rotors moving a tad because the paint
try this, lift up the oddening wheel, unbolt it
look at the rim wher it hits the hub, is there any wear marks
, if so, rotate the wheel a few spots and rebolt up, to specs with a tourk wrench, usng a star pattern when tightening it up
2. could be a wheel bearng,, does the tier and rim shake in your hand when jacked up,
3 the pads could be rubbin, or the pad squeeler could be hiting the rotor,
just bend it back or do a brake job,
the rotor could be wraped, does the brake pedal pulesate upon hard brakeing,
good luck,, i know what a pan in the asss thouse noices are,
Old 11 Aug 2010, 12:52 am
Well, I just had the wheel bearing in that wheel replaced, and just got the alignment done. It wouldn't surprise me if it were the wheel bearing given the mechanic that installed it
Could it be anything else though?
Old 11 Aug 2010, 01:10 am
id bet he didnt pt the lugs on right, and its moving a ll, bit,,
i had mine for lik 6 months,, and i was a service advior, at a chrysler dealership,,
, if it was not tighten properly,,
you get a sqeek noise as you take off,, especily when driving along a fence , as the noise bouncs riht in your ear
Squeaky sound from left front of the car Markwin Tech & Performance Forum 0 29 Jul 2010 10:48 am
wtb pt rims and left front knuckle sleeper_rick Classifieds: Want To Buy 3 20 Dec 2009 05:08 pm
03 GT Front End Vibration veering left logiserv Wheels, Tires, Suspension 10 10 Aug 2009 11:41 am
Left hand turn no wheel stop? xerotime Wheels, Tires, Suspension 2 16 Jun 2009 08:05 pm
Noise from Left Wheel neps Wheels, Tires, Suspension 1 02 Aug 2004 01:00 pm
