fuel level sending unit
Old 13 Aug 2010, 12:15 am
Default fuel level sending unit
Can anyone tell me if the gas tank has to be pulled in order to change out the fuel level sending unit. Apparantly mine is faulty. It goes to zero, then full, then kind of works showing nearly full with 150 miles on the trip meter.
I had it checked and the diagnostic showed an open connection in the sending unit, duh. I already new it wasn't working. Anyway I guess the gauges is good.
Old 13 Aug 2010, 12:38 am
Default Re: fuel level sending unit
yes, it has to be dropped,
its in the center, and has a ring you unscrew and the whole pump comes out the top,
there was a recall that stuffed a pad above the fule pump that was supposed to stop gas from leakng in a flip over,,
so yes,,
Old 13 Aug 2010, 12:17 pm
Thanks. You said the pump comes out?? is the gauge sending unit in the same hole or part of the same unit??
Oil Pressure Sending Unit DEEGO Tech & Performance Forum 20 22 Feb 2016 06:24 pm
oil pressure sending unit mowerman Tech & Performance Forum 11 29 Oct 2009 12:10 am
How do you know if it's a bad pump or sending unit? scrisp2 Tech & Performance Forum 4 18 Nov 2008 08:44 pm
Oil pressure sending unit littleblueGT Turbo Performance 3 27 Oct 2004 02:44 pm
Oil Sending Unit rockycruiser General Turbo Discussions 9 15 Oct 2003 11:30 am
