Transmission shifting in to low gear problem
Old 14 Aug 2010, 08:23 am
Default Transmission shifting in to low gear problem
My check engine light came last night while driving at 60mph, and the transmission went into low gear unexpected. Transmission fluid clear and full. I turned the engine off for 10 minutes, and turned it back on and drove it and it still wouldn't shift out of 1st gear while in drive. This morning I took it for a test drive and it shifted fine for about 10 minutes than dropped into the lower gear for a second than back to normal. Engine light was on when I started the car. The car is an 06 (non-turbo) with approximately 114,000 miles. Any ideas what's causing the problem?
Old 14 Aug 2010, 08:31 am
Default Re: Transmission shifting in to low gear problem
first thing you need to see what code it says than go from there
Old 14 Aug 2010, 09:00 am
karleton,
Here's ya go. Follow the instructions and come back here with the code you find. When you come back, let us know if you've changed the timing belt on your cruiser.
How to retrieve fault codes.
Old 20 Aug 2010, 09:37 am
where does one find a list of fault codes, with explanations for correction?
Old 20 Aug 2010, 09:50 am
Most of the fault codes are here...
Error Codes
As far as corrections, you can Google the number you find or come back here and ask.
Old 20 Aug 2010, 12:20 pm
thanks for the information.
Old 20 Aug 2010, 12:40 pm
Wait a minute, you aren't the one who had the problem in the first post?
Old 20 Aug 2010, 01:01 pm
I hope when you said the fluid is "clear and full" you meant "clean and full" because the fluid should not be clear. It should be bright red. Could this problem be cause by the incorrect fluid type?
-Chris
Old 20 Aug 2010, 01:12 pm
Didn't catch that the first time but I "think" he meant to say that it wasn't black or smelled burnt. The red is transparent on the dipstick (as you know) and can see right through it to the markings on the stick. Anyway he hasn't been back in 6 days since he posted the first time.
Old 20 Aug 2010, 01:15 pm
You're right! I didn't even pay attention to the date
-Chris
PT not shifting out of first gear. Jables General PT Cruiser Discussions 5 18 Oct 2010 11:34 am
stiff shifting into gear - '05 auto trans. m5online General PT Cruiser Discussions 7 01 Oct 2010 01:56 pm
Not shifting into gear Pan465 General Turbo Discussions 1 28 Apr 2009 07:28 pm
2002 pt cruiser 5spd pops out of 5th gear and hard shifting bobby515 General PT Cruiser Discussions 3 03 Jun 2008 08:39 am
Trouble shifting into 3rd gear on 5-speed GT purplept General Turbo Discussions 23 28 May 2004 12:00 pm
