Car is off, Boiling Coolant
Old 14 Aug 2010, 01:37 pm
Default Car is off, Boiling Coolant
I have an '06 Cruiser, 93k miles. Car is not overheating and runs like a champ. Just got home from some errands and I shut the car off and the coolant is boiling and spitting out of the overflow container, so of course I am like WTF? so I pop the hood and restart the car. Cooling fan kicks on, boiling stops and the temperature gauge is reading at normal levels, shut the car off and it doesnt do it again. No issues other than that one episode of boiling coolant. My guess is a radiator cap? Oil is clear and no oil in coolant as far as I can tell. Working on vehicles is new to me, so please bear with my ignorance. Thanks for the help ya'll.
Old 14 Aug 2010, 02:42 pm
Default Re: Car is off, Boiling Coolant
Welcome to the forum.
I one-time occurrence is hard to diagnose but you could be right about the thermostat. You'd also want to check to see if there's any air trapped in the system.
Old 14 Aug 2010, 02:47 pm
Sorry about my ignorance, LOL! I did a radiator flush about 3 months ago, could this be the culprit because I didnt bleed the air out? How would I do this?
Just a chick learning about cars and how to fix them...
Old 14 Aug 2010, 03:06 pm
It's like bleeding air out of a tire but you can be serious burned if you aren't careful. The bleed valve is under the radiator cap (see picture). You push in the center when it's cold and if there's air in the system it will come out. If it does come out, you want to unscrew the radiator cap and fill the system to the top. Hopefully you used HOAT coolant after you flushed the radiator or you'll have trouble in the long run inside the radiator. Then you want to heat the water up until normal temperature and bleed the system again, but this is where either some more air will come out or very hot water if there's no more air. be very careful!
Old 14 Aug 2010, 03:37 pm
Once it cools off outside I will go outside and do that. I just hope its not something serious. Unfortunately I am one of the unfortunate people to get laid off recently, so funds are scarce. From what it sounds like do you suspect something serious or more than likely an easy minor fix? Sorry to be bothersome.
Old 14 Aug 2010, 03:49 pm
"Mama" Welcome to the Forum.
Just try and bleed the air out first. Don't try second guessing on what else could be the matter. It is hard enough to guess what could be wrong let alone how much it could cost to fix.
Old 14 Aug 2010, 05:42 pm
I bled the system and there was not much air if any. Should I replace the radiator cap? My biggest fear is that the temperature gauge inside the car is wrong and I am overheating and run the risk of blowing a head gasket or worse. I unfortunately dont have a temperature gauge to check it.
Old 14 Aug 2010, 05:47 pm
onemat's Avatar
Hi,
What is HOAT collant?
Thanks,
Matt
Old 14 Aug 2010, 06:22 pm
HOAT=Hybrid Organic Acid Technology
It's a Mopar thing from what I have read. I personally used the Glycol based coolant when I did my flush (neon green stuff).
Old 14 Aug 2010, 06:58 pm
I would think if the radiator cap was bad, you would see some signs of of coolant around the area of the cap. As afar as the guage, I've never heard of one going bad, I'm sure they do, but not very often.
On your first thread you said you heard the cooling fan come on. Was it loud. The high speed fan is so loud you can't mistake it whereas the low speed you actually have to see it turning when the engine is running to make sure it's on.
Tags
boiling, coolant, overflow, overheating, radiator cap
Coolant. Zombiess Tech & Performance Forum 4 08 Jan 2014 08:34 pm
Boiling water sound under the hood drivers side csd Tech & Performance Forum 19 20 Aug 2011 08:12 pm
Boiling over - not overheating ionheavens General PT Cruiser Discussions 12 19 Jan 2010 12:01 pm
replaced tranny now its boiling over wreksta Tech & Performance Forum 4 16 Sep 2009 02:22 pm
Coolant help. pt4cec General PT Cruiser Discussions 9 15 Sep 2009 08:28 am
