Windsheild Washers
Old 15 Aug 2010, 10:59 am
Default Windsheild Washers
2006 GT: FRONT windsheild washers just started spraying kind of weak (both sides-uniformly) have been fine since new until now, resivoir is full, stuck pin in nozzles that didn't help, pump sounds a tad bit louder than normal, how would I check this-right now they only spray right at the bottom of the wipers and not the center of the windsheild like they used to-Thanks!
2010:Wife's friend just bought brand new and the rh side washer nozzle seems to always weep-chrysler dealer said "They can't fix it" my feeling is that IF they can't fix it ALL PTs should be doing this-our '06 has NEVER done this.Again, THANKS for any replies and/or suggestions!
Old 15 Aug 2010, 10:04 pm
soonercruiser's Avatar
Cool Re: Windsheild Washers
2010 is under warranty!
Make the stealer fix it!
On my 2006, after the recent severe hail storm, mine got week too.
I don't know if it was just long-term heart & vibrations - or if the nozzle took a direct hit from hail - but, the bottom nib (under the hood) was cracked.
When I get it back from the shop, I will replace the broken one.
Otherwise I got two PTs - one 2006 Touring - and a 2006 GT vert.
Never had a nizzle problem previously.
Frank, aka SOONERCRUISER,
Old 15 Aug 2010, 11:43 pm
06 GT Vert here....both nozzles failed....where plastic connector meets rubber hose under hood was culprit....user SuperGlue to repair....no issues since.
2006 PT GT Vert - 2.4l Turbo, Black/Gray leather, MSD ignition wires, Royal Purple 5w-30 synth oil and filter, Sylvania Silverstar Headlight upgrade, TOYO Extensa High Performance tires
Other rides:
2008 Honda Odyssey Touring Edition, NAV/DVD
2010 Toyota FJ Cruiser 4x4 Trail Teams Edition
Old 16 Aug 2010, 02:10 am
Default Re: Windsheild Washers
The dealer is obligated to repair the 2010. If they refuse or claim they can't your friend needs to contact Chrysler immediately.
I've never had an issue on my 2010 except for once. There's no low washer fluid warning, so when I ran out obviously it quit spraying. I thought something was wrong until I checked the resevior and saw it was empty.
-Chris
Old 17 Aug 2010, 04:35 am
Wink Re: Windsheild Washers
Thanks everyone!! I'll investigate more & advise!
Old 18 Aug 2010, 03:16 pm
MaskMarvl's Avatar
Exactly what happend to me...
Thanks for the tip!
Windshield Washers Squirters delrosen General PT Cruiser Discussions 5 11 Nov 2008 01:54 pm
Auction Windsheild Chalk gamman The Detail Shop 2 19 Feb 2005 09:47 pm
Windshield Washers WAYNEF Exterior Accessories Forum 6 23 Sep 2004 06:11 pm
problem with led washers cheeseball Exterior Accessories Forum 0 23 Aug 2003 09:20 pm
LED washers ptcruz311 Exterior Accessories Forum 2 10 May 2003 03:57 am
