Ignition starter switch
Old 16 Aug 2010, 08:58 am
Default Ignition starter switch
Can someone please tell me where the ignition starter switch is located? I think I have to replace it, but can't find it. Thanks for any help. This is on a 04 Cruiser.
O4 Limited Edition, Gray, Sunroof, Chrome Rims
Old 16 Aug 2010, 03:08 pm
Default Re: Ignition starter switch
The starter switch is where you put the key to start the engine. Unless you've been doing it some other way.
Old 16 Aug 2010, 03:33 pm
Thanks. This looks complicated. I was told that maybe a Chrysler dealer will have to change this part b/c the airbag may deploy.
Old 16 Aug 2010, 03:54 pm
Not sure about the air bag but maybe one of the mechanics will come along and let you know it it's true.
Old 19 Aug 2010, 06:01 pm
Hey Crewinz,
Have you ever had to change this switch before. I'm having trouble getting it off. Any suggestions on how to remove it?
Old 19 Aug 2010, 06:17 pm
No sorry. Never has to do it. See if this helps...
WikiAnswers - Changing ignition switch in 2002 pt cruiser I was told you can not change out the switch but had to put in a whole new steering column costing 1200.00. I think this is BS any answers
Ignition Switch Problem? jjensen101 General PT Cruiser Discussions 8 11 Apr 2013 07:15 pm
'01 Ignition key switch swap out or...? desotocrazy Tech & Performance Forum 3 08 Jul 2010 03:39 pm
Ignition Switch??? Don162 Tech & Performance Forum 2 19 Aug 2009 11:03 am
Possible Ignition Switch? bkarr Tech & Performance Forum 4 20 Jul 2008 06:25 pm
Battery good not sure if is starter or ignition Rob in tx Tech & Performance Forum 3 03 Jul 2007 11:34 pm
