09 CV BOOT,, Help!!!!
Old 17 Aug 2010, 11:54 pm
Default 09 CV BOOT,, Help!!!!
I have a 09 4 cyl that has a torn cv boot. I called the dealer and was told that i would have to replace the entire axel... why is this so? Dealers is the only one who sells axel for $200. i was told by some friends to try and find a split boot that i could use to replce the torn one (avoid dealer and labor). Maybe a split boot from a vw bug? Has anyone tried to replace just the Boot? I am tryng to save $. Thank you
Old 18 Aug 2010, 02:55 am
808's Avatar
808 808 is offline
Default Re: 09 CV BOOT,, Help!!!!
I called my dealership about my torn cv boot and they said it would cost +$200. A local shop patched my torn cv boot with silicone or something just to get by for a little while. The mechanic there then scheduled an appointment for me to get it replaced under warranty. They didn't hesitate to agree, so I got it done for free. Little did they know that it tore during installing my Eibach springs..
Make sure it's only the cv boot and that you haven't waited too long or else too much grease comes out and it'll affect a lot more valuable parts! Good luck.
Old 18 Aug 2010, 03:16 am
Call your dealer again and ask them specifically if the whole axle has to be replaced, why is there a replacment procedure for just the boot listed in DealerConnect? DealerConnect is the tool the technicians would be using, so the dealership has access to it.
They're throwing you for a loop. The replacement procedure for the CV boots is the same for every basic application. Remove the axle shaft, remove the clamps and pull the boot back, remove the CV joint, remove and replace the boot.
-Chris
Old 18 Aug 2010, 08:45 am
Dino's Avatar
If it's an 09 shouldn't they be fixing it for nothing, I can't believe it went already. If it's not covered and your dealer wants to hose you take it to a trusted local mechanic. If you don't have one talk to a neighbor or friend, I have had the same mechanic for 15 years, once you find a good honest one you stick with him.
Old 18 Aug 2010, 12:11 pm
If he's not the original owner, it would depend on his mileage. Also, unless the dealer can determine that the boot failed rather than being torn open by an object of some sort, it likely wouldn't be covered.
-Chris
Old 18 Aug 2010, 08:15 pm
It was torn by running over an object. There is slight damage under the bumper that eliminates me from claiming manufacture defect. I called the stealership and was told i would have to buy the entire axle because they dont sell the CV boot alone. I am greatly considering taking it off and finding a similar size split boot i can put on. I refuse to pay the stealership my hard earn $$$. I know other people have gone through this and am hopeing for some insight. So if any of you guys have any ideas or heard of a McGuyver trick please let me know. Thanks guys.
Old 19 Aug 2010, 12:27 am
Perhaps you didn't read my first post
The boot is servicable by itself and is sold seperately. I don't want to say the dealer is deliberately lying to you, but what they're telling you is not the truth.
I work for a dealer so I have access to look up this information directly from Chrysler. Do not use a Quick Boot. They're simply held together with an epoxy that "welds" the two sides together by a chemical reaction and they can fall apart pretty easy with normal use.
Just pick up a factory boot, or go to any parts store for that matter and pick one up there.
The part number for the outer boot kit is 05083090AA
The part number for the inner boot kit (just for reference) is 05014912AA
-Chris
Old 19 Aug 2010, 10:15 pm
NON OF THE LOCAL AUTOPARTS CARRY THIS ITEM,, EVEN WHEN I GOOGLE THE PART # NOTING COMES UP. IS DEALERDIRECT AN AUTHORIZED DEALER WEBSITE ONLY? IM GOING TO TRY THE STEALERSHIP TOMORROW,, GIVE THEM THE PART NUMBER AND HOPE FOR THE BEST.
Old 20 Aug 2010, 07:46 am
The use of all capital is the same as shouting, please do not shout as we read and do not listen. heifetz17 works at a dealership and is pretty good at giving advice and correct part numbers that the dealer has access to.
Old 20 Aug 2010, 12:45 pm
You didn't search very hard. Less than 5 minutes of searching turned up this:
Specialty Products 33001 - CV Boots | O'Reilly Auto Parts
Yes, dealerconnect is a dealer only website. The part number I gave you is an OEM part number. Give it to the parts dept of your dealership.
-Chris
Do you use your Top Boot? SantaGuy PT Cruiser Convertible Forum 72 29 Sep 2010 08:13 am
Boot TheGov72 PT Cruiser Convertible Forum 2 19 Aug 2010 06:18 am
Tie rod and cv boot abidehandy General Turbo Discussions 3 23 Jun 2010 06:44 pm
CONVERTIBLE BOOT edl General PT Cruiser Discussions 1 01 Apr 2009 09:11 pm
BOOT edl PT Cruiser Convertible Forum 0 01 Apr 2009 07:50 pm
