04 cruiser won't start!! HELP PLEASE!!
Old 19 Aug 2010, 09:36 pm
Default 04 cruiser won't start!! HELP PLEASE!!
ok here's my situation.
04 Cruiser that won't start. Here's what I have done. Replaced the battery, had the started checked and it was fine. Replaced the ground cable going to the battery. Replaced the ingnition starter switch on the steering column. Car still won't start. I have tried jump starting it from the starter. The starter will turn over, but still won't start. I ahve checked all the fuses and switch the relays around, still won't start. Is there anything else I can do before I take it to the dealer? I'm really trying to do this on my own, but its looking like the dealer the going to get my business and my money. Any suggestions would be greatly appreicated.
O4 Limited Edition, Gray, Sunroof, Chrome Rims
Old 19 Aug 2010, 09:45 pm
Default Re: 04 cruiser won't start!! HELP PLEASE!!
Is their any fault codes on the computer and how many miles on it?
How to retrieve fault codes.
Old 19 Aug 2010, 09:47 pm
117K and no codes. when I switch the car on, everything comes on normal, but when i turn the key, it just clunks, starter won't turn over.
Old 19 Aug 2010, 10:01 pm
OK, one last question. Did you have the timing belt changed yet?
Old 19 Aug 2010, 10:04 pm
yes about 6 months ago, had a burnt valve, so had the heads done over along with timing belt and water pump.
Old 19 Aug 2010, 10:12 pm
Can't tell by your posts if the engine is turning over and won't start or it won't even turn over. If it is, you have tow things to look for: spark and fuel. Have you checked the No#13 fuse in the PDC (fuse box) in the engine compartment? It's the fuse for the fuel pump. The other (spark) might be a bad coil, not sending spark to the plugs but I think you should have gotten a fault code for that.
Old 19 Aug 2010, 10:14 pm
When I turn the key, the engine is not turning over, but when i jump start it from the starter, the engine will turn over. I have check all the fuses inside and outside.
Old 19 Aug 2010, 10:25 pm
OK, so the ignition starter was replaced, starter checked. Starter turns over when directly jumped but not when you use the ignition. Sounds like the starter solenoid has gone out or a bad connection to the solenoid from the ignition or battery. Some say you can't buy the solenoid by itself and a whole starter/solenoid has to be bought but then other say it can be bought separate. I can't say which.
On another thread where BeagleDad had a broken green wire that he didn't know where it went and the car wouldn't start, I found out it was broken off the solenoid. It should have a large green and a large red wire going to the end bold on the solenoid.
Old 19 Aug 2010, 10:29 pm
The green wire is there. I guess I will check tomorrow to see if I can get the solenoid separately. I really appreciate your help. Will let you know tomorrow if changing the solenoid works.
Old 19 Aug 2010, 10:31 pm
OK, thanks.
2002 PT CRUISER WON'T START -98k MsLeah General PT Cruiser Discussions 9 12 Jun 2010 08:19 pm
2006 PT Cruiser GT won't start anglii General PT Cruiser Discussions 5 14 Nov 2009 10:10 am
Co-workers cruiser won't start shaX07 Tech & Performance Forum 6 13 Nov 2009 08:44 am
PT Cruiser Engine Start Up skylight PT Cruiser Videos 0 28 May 2008 07:48 pm
01 PT cruiser wont start.. EvilWRX General PT Cruiser Discussions 1 12 Feb 2007 02:35 pm
