High Beams Stopper Working
Old 22 Aug 2010, 11:34 pm
Default High Beams Stopper Working
I am officially stumped. The other day while driving to work I went to flip on my high beams and instead my headlights turned off. I had experienced this before and it was just a dirty contact in the multifunction switch so obviously that's the first thing I checked. No dice.
Next I switched out the multifunction switch entirely with one that I know works. Again, no dice.
Next I switched the headlight relay (inside the fuse panel on the lower left) out with one I know works; no dice.
So here are the symptoms summed up:
Low beams work normally. When the high beam switch is triggered the low beams turn off, the high beams don't come on, and the high beam indicator on the dash does not illuminate.
I can't imagine that both bulbs went at the same time, and also if the high beam fillaments are blown why are my low beams turning off?
The only other thing I can think it might be is a bad ground but why would the low beams and high beams use a different ground?
Does anyone have any suggestions as to what else I could check? Thanks!
Oh yeah and my car's inspection expires at the end of the month so I have to fix this and fast.
Old 23 Aug 2010, 07:26 am
Default Re: High Beams Stopper Working
To turn on high beams, you must push the lever forward. I tried a few things before I discovered that. I was pulling the lever back and releasing it and couldn't figure out why the highs wouldn't stay on. DUH!!!!!
Old 23 Aug 2010, 08:34 am
The '01 you pull the lever backwards but that doesn't matter. I have driven the car for a few years now I don't think I suddenly forgot how to turn on my high beams. Thanks for the reply though.
Old 25 Aug 2010, 07:30 am
Could be the multifuction switch.
To troubleshoot this, you need a meter or a 12V test lamp.
There are (I Believe) separate fuses for L & R bulbs - turn switch to high beams and check the fuse sockets for 12V, if good, check lamp sockets for 12V...
It may point to the switch.
Help a/c is not working just4kicks Tech & Performance Forum 5 20 May 2010 10:49 am
high brake light not working bobcatss66 General PT Cruiser Discussions 3 10 Mar 2009 01:32 pm
Low Beams and High Beams jingks Exterior & Interior Styling 3 24 Jan 2008 03:16 pm
No low beams in cold weather...sort of mike999 General PT Cruiser Discussions 2 10 Dec 2007 11:59 am
Still working turbomangt Vendors & Buyers Forum 4 29 Nov 2003 09:30 pm
