Steering Noise
Old 06 Sep 2010, 08:30 am
leftoverture's Avatar
Default Steering Noise
2001 PT Cruiser Limited. When turning the steering wheel at low speeds I hear a "wiping" noise. Higher pitched, but not a squeal, more like wiping. Anyone know if there's a lubrication point or something in there?
2001 PT Cruiser Limited Edition
Old 06 Sep 2010, 03:37 pm
Default Re: Steering Noise
Usually it's a clicking noise and it's the clock spring inside the steering column. Never hear of a wiping noise.
Old 06 Sep 2010, 04:36 pm
Definitely not a clicking noise.
Old 03 Oct 2010, 07:55 am
Does anyone have an answer to this?
I've got the same noise on my 2001 LE. Squeaking/wiping noise. Pitch varies with the speed at which the wheel is turned (lower pitch when the wheel is turned slowly).
I can also feel a minute amount of vibration through the steering wheel, so it seems evident that there is some contact/friction in the steering wheel that maybe needs lubrication.
The wheel turns smoothly. It doesn't bind up and I don't feel any drag. So, is there anything wrong here, or can I just ignore it? If it is the clockspring, what will happen if it eventually fails?
Old 03 Oct 2010, 09:22 pm
Bump...anyone?
Steering Noise...someone help! whitbyPT Wheels, Tires, Suspension 1 29 Oct 2010 07:04 am
Steering Noise zsplain Tech & Performance Forum 11 02 Nov 2009 04:53 am
Power Steering Noise topdownvert General PT Cruiser Discussions 3 29 Nov 2008 01:49 am
steering column noise 4SPEED General Turbo Discussions 2 12 Sep 2006 03:33 am
steering noise !? COP TZER General Turbo Discussions 15 18 Jul 2003 06:33 pm
