winscreen demister no air
Old 14 Sep 2010, 09:20 am
Default winscreen demister no air
Had this 2001 Pt crusier tourer for 5 months the and the winscreen demister has no air flow has any other owners had this problem, as the winter is just around the corner I need to get this working. Also just past MOT and only needed side lamp and fog lamp
Old 14 Sep 2010, 11:20 am
Default Re: winscreen demister no air
I have not had that problem but the following is From my service Manual:
Possible Cause for no forced air in Defrost Position:
1.Vacuum line pinched or leaking.
2.Faulty heat, defroster, or mode door.
3.Faulty selector switch.
4.Vacuum check valve.
Correction
1.Locate and repair vacuum leak or pinched line
2.Test actuators and door operation. Repair as necessary.
3.Test selector switch and replace if necessary.
4.Test check valve and replace if necessary.
Old 15 Sep 2010, 08:40 am
Thanks I will try this advice
Donny
Old 15 Sep 2010, 03:10 pm
twress's Avatar
Is the air flow coming out of the vent coming out alright when there on? Or is it just the defroster that nothing is coming out of it? Could be the fan motor if nothing is coming out of the other vent when they are turned on...
ROUNDIN UP THE WAGONS 02 LIMITED WOODY, 89 CAPRICE CLASSIC
Old 19 Sep 2010, 02:49 pm
hi twress
There is only air comming from the vents under the dash and the side window vents
Old 26 Dec 2011, 07:44 am
Hi Donny
How did you get on. I get air out of the centre vent up to the windscreen, but demisting the car is the probably the worst car I have ever had. If I get the windscreen clear then the side windows mist up, once I get them clear the windscreen is misted again.
I love the car but hate the demister.
Old 26 Dec 2011, 10:05 am
Hi there my son took of the center panel and found a linkage was disconnected since the all has been ok
