Check engine light then limp mode
Old 16 Sep 2010, 07:04 pm
Default Check engine light then limp mode
Wife was driving at 75 mph and suddenly the car felt to her like it was stalling and the check engine light started flashing. She made it to the shoulder and the car never stalled. The check engine light continue to flash. She shut off the car and waited for me.
I did the key dance and got three codes: P0300, P0315, and P0339.
I disconnected the negative on the battery for 30 seconds to clear the codes. The car started and ran fine. I drove it home about 15 miles without a hint of a problem.
I recently changed the timing belt, water pump, plugs, wires, and put in a new camshaft position sensor. Any ideas what happened?
Old 16 Sep 2010, 07:19 pm
Default Re: Check engine light then limp mode
Both 315 and 339 refer to the Crankshaft Position Sensor. First, are you sure you changed the Camshaft sensor? If yes, did you use a Chrysler part? If no, PT Cruiser don't like aftermarket (auto store) electrical parts. It may cost more but worth it in the end.
So, If you did change the CAMSHAFT Sensor, looks like it's time to change the CRANKSHAFT sensor. Sorry, but you may still have a problem with the CAMSHAFT sensor if it's aftrermarket.
Old 17 Sep 2010, 07:47 am
I definitely changed the camshaft psotion sensor with a dealer part. I guess I will go buy the camshaft sensor and replace that one too. Should I wait until it throw the codes again or just replace it now.? The car continues to run fine since I cleared the codes. Thanks for the input.
Old 17 Sep 2010, 08:20 am
Yes, I'd wait to see what happens and see if the new codes (if any) still point to the Crankshaft sensor.
Old 18 Sep 2010, 11:44 am
ejstith's Avatar
I just had the crank sensor changed on my '05. I had a shop do it, cost $73 for entire job parts & all. It's worth it to me as the only way I could even see it was with a mirror. It didn't take the mechanic 15 minutes to change it. I had a 0339 code too and this seems to have fixed it so far (X)...
2005 PT, Limited turbo Lite. Automatic all whistles and bells.
Old 20 Sep 2010, 02:25 am
I disagree 100% NEVER wait until something fails and potentially leaves you stranded to fix it. You already had a flashing check engine light, which basically renders the car non-driveable and it threw a code for a crankshaft sensor.
Just buy a new sensor and replace it. Next time the car could stall and not start, and leave your wife miles from home and nothing she can do.
Disconnecting the battery and clearing the codes doesn't magically make the problem go away, so take care of it now before it comes back.
-Chris
Limp Mode? Bentron General PT Cruiser Discussions 23 21 Jun 2016 10:54 am
help..limp mode ivynthemnts758 Tech & Performance Forum 2 09 Sep 2010 08:44 am
Stuck in limp mode. Cleared some codes, but... SRT8guy General PT Cruiser Discussions 2 30 Jul 2010 07:15 am
01 cruiser in limp mode mui5m General PT Cruiser Discussions 1 04 Dec 2009 02:19 pm
Engine overheating, Stuck in "Limp mode" showing codes 0188,1490,&1495 Manny Tech & Performance Forum 4 08 Apr 2009 05:39 am
