06 base--oil drain plug location
Old 18 Sep 2010, 09:13 am
Default 06 base MANUAL TRANNY--oil drain plug location
Well, I've always changed my own oil since I got my first car in 1982, and I've never seen a situation like this one. I got under the car (a feat in itself if you don't have jackstands) and saw that I could most likely do the oil change without jacking the car up (good because I don't have jackstands).
However, the oil pan appears to have two drain plugs. I can't believe they're both for the oil, so which one IS for the oil? The one on the driver's side, closest to the oil filter, seems most logical to me...but then I'm not a car company.
The car has a MANUAL TRANSMISSION, if that makes any difference.
Can anybody clear this up for me? Thanks!
Old 18 Sep 2010, 09:18 am
Default Re: 06 base--oil drain plug location
There should only be one drain plug. No#5 in the picture below. Not sure what other plug your looking at.
Did you buy the car used? Maybe someone stripped the OEM plug and put another one in.
Old 18 Sep 2010, 03:36 pm
CREWZIN, are you sure this applies for manual transmissions too? I remember vaguely hearing something about the drain plugs for the trans. & the oil being close to each other--but of course I can't find that online now that I need to. Just can't be too sure, KWIM?
Old 18 Sep 2010, 03:54 pm
Yea it does make a difference and I see you added that you have a manual trans. The manual does have it's own drain plug or maybe it's a fill plug, but anyway, the oil pan should have the drain plug in the same position as in the picture, next to the oil filter.
Helicoil for oil drain plug? eflyguy Tech & Performance Forum 2 09 Apr 2010 04:10 pm
Oil Drain Plug! Tech General PT Cruiser Discussions 9 19 Oct 2009 01:19 am
Oil drain plug AlmondTurbo General PT Cruiser Discussions 2 07 Feb 2007 04:54 pm
oil drain plug tagreen95354 Tech & Performance Forum 14 05 Feb 2006 09:37 pm
Drain plug DREAM2 General Turbo Discussions 11 06 Jul 2004 10:14 am
