Rocker panel rust!
Old 27 Sep 2010, 04:22 pm
oldcoach's Avatar
Default Rocker panel rust!
Anyone have the rust repaired at the rear wheel rocker panel area?
Is this something I should take to a pro to have fixed?
I do know that I need to remove the shields and clean out all the junk that I find inside the rocker and fix the rust in that location also.
02' Black Woodie Limited Edition Drop in K&N Air Filter w/air box mod. 06 tail lights, Limo tint all around, orange LED interior, Mopar 8 inch sub, Stull side pipes. Silver stars upfront, a little chrome
Old 27 Sep 2010, 06:30 pm
Default Re: Rocker panel rust!
PRO, as an EX body man, there is only one way to get rid of rust, REMOVE IT completly, cut it out, and thats not something to try unless you have done it before, or have lots of time to get it right.
I live where they use SALT on the roads so Am also concerned about the rust areas of these cars. I did notice in the back corner, inside the fender well of the rear tire is Hole .. so to speak, its jsut a spot where there is no plastic, no liner nothing (its factory, not a rust hole).. that has to be a horrible spot to build up dirt and water... hence rust in front of rear wheels.. Seems really stupid to have a hole there. I havent looked alot, maybe its not a spot anything can collect.
Old 27 Sep 2010, 08:34 pm
wow, are you sure it was not hit in that area ,,
i have not seen any rust on the ones here in the jersey shore,,
my 2001 has rust only where it was repaired,
sorry,,
use a pro, not the cheapest, macco,,
Old 28 Sep 2010, 03:19 am
oldcoach's Avatar
They say that rust never sleeps, so I must get a closer look at the area and see if I can correct the issue or if I must take it to a pro. I'll post some pics of what I find.
Old 28 Sep 2010, 04:29 am
Candyman's Avatar
Smile Re: Rocker panel rust!
Hey their oldcoach,
I am going to have to agree with going ahead and taking it in to have someone fix it in a Shop. As previously mentioned, the only real way to cure the cancer is to cut and remove the effected sections, and either fabricate or find some new panels and fill in the spots where the problem was. You will need a Torch, Welding Equipment, Body Tools, and a good working knoledge of working with sheet metal, body fillers, correct primers, and finally paint and primer both of which are required by Federal Law now to be Water Borne Primer and Paint which is way more expensive compared to the older Solvent Base, and though the newer Water Borne lays down nicely, and is relatively easy to work with, it also lays down really watery kinda like Candies do so its way easy to wind up with defects or runs if not right on top of things, and Water Borne Paints tend to take way longer to dry so its a good idea to have that booth and ovens to bake the Paint.
So with all the stuff , and knowledge you have to have to pull something like this off, and do it correctly, its just not worth it not to have someone with the tools, background, and shop to do it. You don't want to mess around when correcting Rust as it could so easily spread and create even more of a mess. That's my two Cents on it anyway for what its worth.
I wish you the best as always. Let me know if I might be of anymore help.
Check out my Custom PT Club Website: http://westvalleyforum.proboards.com/index.cgi
And my ever growing PT Photo Archives: http://s458.photobucket.com/albums/q...uiserArchives/
Please Like my Hot Rod Restoration and Detail Shop on Facebook.
https://www.facebook.com/BlueDiamondDetailing
Old 28 Sep 2010, 07:32 pm
VNT's Avatar
VNT VNT is offline
Are you talking about this area
see attached, rear wheel well with inner plastic insert removed.
Notice muck in the bottom. I cleaned it out, painted everything in there with Eastwoods Rust encapsulator and top coated with Chasis Black. Then coated with Anti rust.
ALso pulled the two rubber grommets and flooded the inside of the rocker with Fluid Film, note have nothing to do with the websire listed , just info on the product
http://www.fluid-film.com/
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 25 Oct 2010, 08:26 am
oldcoach's Avatar
Any one know what the rust through warranty is on a 2002?
After removing the side pipes and getting a close look at it, the rust is all the way through the rocker and that will tak some work to fix. Looking to see just what the body rust warranty is.
Old 25 Oct 2010, 10:34 am
Do any cars have a rust warranty? I know there was a short time it was mentioned, but I havent heard anything in the last few years. 2002, I really doubt its anything over 3 years (isnt that the standard Chrysler warranty?). I feel for ya, I had a 2002 Alero 2 door, it had rust in front of rear wheels in 2006.. 3 friggin years.. and the car was kept clean and not drove on anything but pavement.. I live on the MN border in ND, I "think" MN still uses salt on the roads during winter.. evil stuff. Just some spots on cars Dirt collects, then gets wet, no air or sun to dry it.... Like sitting it in a bucket of water, rust will happen.
Old 27 Oct 2010, 12:17 pm
I believe the Chrysler warranty was 5 years "perforation" repair. 3 years on paint.
Chrysler in Canada sold a 10 years rust warranty as an extra. It was an application of a wax type product.
2001 Taupe Limited 5 speed manual. Bought new and the first one to be sold by the dealer.
Rusted-out rocker panels? BGW Exterior Accessories Forum 3 30 Sep 2009 12:01 pm
fixing Rocker panels majorstash General PT Cruiser Discussions 7 16 Aug 2009 08:26 pm
Mopar Rocker panels PT4U2C Exterior Accessories Forum 3 17 Sep 2004 04:19 pm
Rocker or Toggle switches Carmens Cruiser Exterior & Interior Styling 5 26 Mar 2004 05:34 pm
Adding Rocker Switches Stephen R. Interior Accessories Forum 8 13 Sep 2003 11:02 pm
