LED flasher
Old 28 Sep 2010, 06:45 pm
Send a message via MSN to CHARGERFORCE
Default LED flasher
Ok so i put LED tail light in my 2003 PT Cruiser GT... So my turn singles blink fast i new that would happened so i got a LED flasher but it still blinks fast? Any help?
The blinker is the 5pin malty-switch on the bottom left of the fuse pale in side the car right?
2003 PT Cruiser GT 2.4L Turbo
2.5inch cat back MagnaFlow Exhaust
Stage 1BOV
K&N Cold air intake
MTX sledghammer sub
MTX 4004 Amp
MTX 6001 Amp
Infinity Speakers
Stinger cap
Pioneer head unit
Old 28 Sep 2010, 06:58 pm
Default Re: LED flasher
Google is your friend.....
Help with LED tail light bulbs, fast flashing like bulbs are burning out - YotaTech Forums
LED Tail Light Question
LED Tail Light Bulb Replacement - Pontiac Solstice Forum
Old 29 Sep 2010, 06:55 am
Here is why the fast flash is happening. The vehicle's electronics look for the resistance of the incandesent bulb to know it is still good. It is flashing because it thinks the LED is actually a burned out bulb. You can actually put the old bulb back in in parallel with the LED and then it will not fast flash or install a resistor. But it must in parallel not series.
Old 29 Sep 2010, 08:29 pm
thank
i put a led flasher in and it still blinks fast i think im going to try and get a different flasher
Stage 1BOV
K&N Cold air intake
MTX sledghammer sub
MTX 4004 Amp
MTX 6001 Amp
Infinity Speakers
Stinger cap
Pioneer head unit
Old 30 Sep 2010, 09:03 am
Before you get a different flasher, check out the automotive section of www.superbrightleds.com. I get all my LED's from them and they have resistor modules so that your car will stop freaking out and flashing the LED too fast.
2005 2.4L Non Turbo
Old 28 Aug 2011, 11:52 pm
SillyRobot's Avatar
I put LED lights in my 2002 LTD Cruiser. License plate lights, Rear tail/brake lights, 3rd brake lights and rear turn signals. I was getting the same rapid flash because of the low voltage demand by the LEDs.
I actually liked it, but I have learned that in some states it can be illegal, like having an actual burnt out bulb. But I found a recommended replacement for the flasher unit (Which is under the upper steering column cover, BTW).
The stock unit is an OMRON 0661A2.
I replaced it with a Tridon Lighting Control Module: LM470 ($29.99 @ AutoZone). Novitá Technologies
It works perfectly. The audible clicker is a little louder, but it is a bit tinny.
The LM470 says it's LED compatible and should work with various Chrysler, Jeep, Dodge and Plymouth vehicles from 1995 to 2006.
Flasher Fuse #18 Blows Need Help F7daved Tech & Performance Forum 2 08 Mar 2010 05:53 pm
SCT Flasher For Sale SilverSleeper Classifieds: For Sale/Trade 2 25 Feb 2010 05:59 pm
SCT Flasher For Sale SilverSleeper General Turbo Discussions 0 23 Feb 2010 04:27 pm
