Wheel Bearing Mystery Solved?
Old 01 Oct 2010, 07:23 pm
mdfrodolives's Avatar
Default Wheel Bearing Mystery Solved?
I was "Cruzin" the net on PT subjects and found a neat PTCruizer "How To" information guide--Ptcruizer.com. While reading some of the info I came across some info about failed wheel bearings in PT's.
There have been discussions on this forum about loose wheel nuts, or just plain bad bearings in the barrel on the day this or that PT was built; but they mentioned in this forum something different--and not so obvious.
Apparently, your wheels create an electrical charge, while turning. Makes sense to me ... anyway ... there is supposed to be a "strap" that carries this electrical charge to ground--thus bypassing your bearings. If the strap is loose or missing, the electrical charges start working away and pitting your bearings, and causing eventual failure--despite having plenty of lubricant.
Anyone ever heard of this? Apparently, the later PT's had ground straps that the earlier ones didn't have (cause Chrysler realized they had a problem).
I don't see how it works, but it makes for a good forum topic.
Any opinions?
Tim
Old 01 Oct 2010, 07:58 pm
Default Re: Wheel Bearing Mystery Solved?
Tim,
I've been passing that information on to whoever would listen for about a year. There's probably about half a dozen topics on wheel bearings that I posted that information along with a picture of my front wheel with the ground strap pointed out. Here's just one of the threads that I gave out the information back in March of this year. ...and the early PT's did have the ground wire as you can see from the picture of my PT that came off the assembly line in Sept of 2000.
ground wires from body to front struts?
Old 01 Oct 2010, 10:57 pm
Crewzin, it's the first I've heard of "static wheel-bearing wear".
The article I read mentioned that Chrysler came up with the "fix" (the ground strap") on later models. But your info (and pic) show just the opposite. So it looks like most of the "bearing problems" are still just a matter of whether or not you got the good ones that day when they fished them out of the parts barrel ....
Thanks, Crewzin.
Tim
Old 02 Oct 2010, 11:25 am
Unfortunately there's no good way to tell everyone that's on the forum or comes to the forum all the good information that's in the threads that are already posted. Most don't use the search which would bring up almost everything that's already been covered. The problem is that the search brings up tons of threads and nobody really wants to read that much.
Old 02 Oct 2010, 06:43 pm
well crewzin, not only you have to read but you have to qualify and decide wheather you have the same situation or not, for beginners or none mechanical background it would be really difficult to decide, besides that this is a forum so people interact with each other not liberary i'm not trying to be a smart ass but i really like the sticky's that you write or other members write as it has precise information and detailed instruction of how to deal with the problem in hand. i wish if there are more of them
Old 02 Oct 2010, 07:02 pm
Have you seen the sticky in the Tech & Performance part of the forum that entitled HOW TO ? It has a dozen or more HOW TO's and I've been adding to it as we go along. If there's something else you don't see, maybe I can find it and add it to the list if I think there might be enough interest from a lot of owners.
HOW TO's
Old 02 Oct 2010, 07:43 pm
HOW TO's
that's the first thing i look for before posting actually, while i try looking at all threads that you posted or replies you answered when i have time (i look at other members reply's or threads as well ) and i saw your note for the wheel bearing static cable, i even went and double checked it to verify it is still there and not loose or damaged
Old 02 Oct 2010, 08:08 pm
I'm flattered or amazed that you look for my posts. I'm just here a lot and see most of the new posts before a lot of the others. That's what I get for being retired. I think I get it 'right' for the answers, most of the time but have been caught giving answers that could have been better.
Old 02 Oct 2010, 09:40 pm
soonercruiser's Avatar
Thumbs up Re: Wheel Bearing Mystery Solved?
Be "flattered" Crewzin! WE all look forward to you tech answers!
Frank, aka SOONERCRUISER,
Old 02 Oct 2010, 10:03 pm
He said with a wink.
wheel bearing and hub replecment. monitor51 Wheels, Tires, Suspension 1 21 Aug 2010 01:13 pm
Wheel Bearing install cjb15 Tech & Performance Forum 5 23 Sep 2009 11:59 am
which wheel bearing musicmanchuck4 Wheels, Tires, Suspension 0 08 Apr 2009 06:48 pm
WHEEL BEARING TOPIC AGAIN!! mjb457 General PT Cruiser Discussions 3 03 Apr 2008 09:48 pm
front wheel bearing debspt Tech & Performance Forum 1 01 Oct 2006 11:42 am
