Oooghhha horn install...
Old 03 Oct 2010, 08:59 am
chigger_ns's Avatar
Default Oooghhha horn install...
How did you install your horn?
Did you just hook it up to where the factory horns are (for wiring too?)?
Or
Did you make a new circuit using a relay?
Where did you mount the horn?
2001 PT 5 speed Touring Edition
Eibach Pro Springs, Energy Suspension HyperFlex Master Kit bushings, 17" RTX Euro wheels, K&N drop in air filter, MotoMaster flat plate AGM battery, KYB GR2 shocks and struts, Booger standard shifter bushings, Ooogah horn.
Old 03 Oct 2010, 09:11 am
Default Re: Oooghhha horn install...
If you have an after market air filter there's plenty of room under the new filter to mount the horn (see picture below). If not, some people mounted them where the OEM horn is but that muffles the sound pretty good. Other places to mount are in the front of the car at the center bar behind the grill and I've seen them mounted beside the left side of the computer facing downwards.
Depending on the year of your car, the 01-05 PT's have 5 spare fuses in the fuse box in the engine compartment to grab the positive voltage. I ran the negative wire inside the car to a push button on the dash and then grounded the button. That means the horn is always hot but not grounded till I hit the button inside. NO relay needed.
Horn underneath the air filter.
Red square spring loaded push button in the dash for the Ahooga Horn. Other lighted switch is for undercar LED lights.
Old 03 Oct 2010, 09:20 am
chigger_ns's Avatar
Have many guys just used the stock wiring and just replaced the factory horn with the oooogahhh?
BTW thanks for your info!
Old 03 Oct 2010, 09:26 am
The Ahooga Horn is 12V just like the OEM horn so it should work with the regular wiring. I'm not sure how much room there is under the inner fender for the Ahooga Horn. You'll find out when you take the inner fender off. I've seen a picture with dual air horns in place of the OEM horns so the Ahooga Horn should fit.
Old 05 Oct 2010, 07:06 am
With the stock air filter a good place for the horn is under the plastic at the base of the windshield where the wiper motor is. I press fit the horn using stiff pieces of foam.
I did use a relay, and an inline fuse - took power right from Battery.
I put the horn switch button in the steering column shroud near the wiper stalk
Old 18 Oct 2010, 08:38 pm
kb9tkb's Avatar
I had my dad install my ooga horn. He was able to put it where the factory horn was using the factory bracket and wires as well.
2007 Marine Blue Touring Edition
Last edited by kb9tkb; 18 Oct 2010 at 08:44 pm. Reason: forgot to add my car to the post
Old 19 Oct 2010, 02:12 am
chigger_ns's Avatar
IS it loud enough?
Thanks!
Horn coponova Tech & Performance Forum 8 01 Apr 2009 11:03 am
New Horn Sandy-GRR8PT General PT Cruiser Discussions 11 06 Apr 2006 08:40 am
OK where is the horn Jimbo General PT Cruiser Discussions 8 31 Mar 2004 10:21 am
Horn Jimbo General PT Cruiser Discussions 8 29 Mar 2004 10:40 am
the horn turbomangt Sound and Security Forum 16 28 Feb 2003 08:09 pm
