Auto Transmission noise at startup
Old 04 Oct 2010, 08:41 am
onemat's Avatar
Default Auto Transmission noise at startup
Hi All,
My PT is a 2008 with an Automatic.
Beginning last week, the morning temps have dropped to the thrities and I've got a noticiable noise coming from under the car at startup. It sounds like a metalic moan, and it sounds like it moves from right to left, like it's associated with something turning, mostl ikely in the AT. As soon as you begin to roll the noise disapears. Shifting seems normal. It's got me worried. Fluid level is normal and the fluid looks good. Anybody got ideas and advice? It will be very much appreciated.
Matt
'08 Touring Edition
Pretty much untouched at this point.
Old 04 Oct 2010, 09:49 pm
mdfrodolives's Avatar
Default Re: Auto Transmission noise at startup
Put your car in neutral and rev up the engine a little to see if the noise changes--or disappears. Do NOT engage any gear when doing this. If the noise changes, I'd suspect something to do with the engine--perhaps a serpentine belt adjuster bearing--or any number of engine maladies.
But first, try to pinpoint if the transmission is really the culprit by disengaging it from the engine by using the trick above. Of course the trans is doing something--even during this test--but not a whole lot.
Hopefully, it's an engine problem that's not too deep.
Tim
Old 05 Oct 2010, 08:24 am
^^^^ Agree.
And , try turning the steering wheel - power steering pump is a regular culprit for noise.
Old 05 Oct 2010, 09:50 am
onemat's Avatar
Thanks guys for all the help and suggestons. OK, this morning I put it in neutal before cranking. The noise and slight vibration was still there and it feels like it's direcly under the car. I kow that what we hear and feel can be a bit mis-leading so I really have know clue. I guess I have to decide whether I'm going to the dealer or a transmission place.
Matt
'08 Touring Edition
Auto Transmission...junk? rogert General PT Cruiser Discussions 21 12 Aug 2010 05:49 am
Auto transmission cooler MINIHEMI46 Turbo Performance 22 16 Feb 2008 12:03 pm
2002 2.0 Auto Transmission NZCruiser Classifieds: Want To Buy 3 08 Jul 2007 04:38 pm
Rebuild Auto Transmission strangelove Tech & Performance Forum 9 30 Oct 2006 09:48 am
Auto. Transmission Question DennisB Tech & Performance Forum 5 08 Mar 2003 02:27 am
