Automatic Trans question
Old 17 Oct 2010, 06:55 pm
mopar1cjh's Avatar
Default Automatic Trans question
Does any one know if you can install an autostick shifter to replace a regular auto shifter without having the dash and TCM for the autostick. Will it still function as a regular shifter. Thanks for any help. Plan on trying to upgade to an autostick later but have a chance on getting a good deal on an autostick shifter.
MOPAR OR NO CAR!
2005 CL Vanilla Touring Edition Convertible 2.4L Turbo Auto
K & N Drop In, MSD 8.5 MM Wires, Hood Scoops, MOPAR Rear Spoiler, Aeroforce Interceptor Dual Scan Gauge, MOPAR Stage 1 Upgrade, AMX Intake Pipe, 225/50/16 Cooper Zeon RS3-A Tires on MB 16 X 7 Alpina Rims with MOPAR logo, Power Slot Rotors, Hawk HPS Pads, Air Box Oil Catch Can, GTS Head Light Covers, Cover Craft Front End Mask. "Coming Soon" AMX Intercooler Pipes, B Woody Mounts, Strut Bar, MOPAR Ground Effects Kit, Gold Line 2" Lowering Springs, KYB G2 Struts & Shocks, GT Instrument Cluster, Auto Stick Conversion
My Other Rides:
1971 Plymouth Roadrunner 340 Auto Sassy Grass Green Numbers Matching with Air Grabber
2003 Dodge Dakota Quad Cab 4X4 4.7L Auto Flame Red Stage 1 Jet Performance Chip, K & N
2004 Jeep Grand Cherokee Freedom Edition 4X4 4.0L Auto Inferno Red
Old 19 Oct 2010, 08:05 am
Default Re: Automatic Trans question
Hmmmm.
I don't see why it wouln't work, but then the TCM may not recognize autostick commands....
Old 19 Oct 2010, 01:56 pm
mopar1cjh's Avatar
I found a procedure to swap out a regular auto shifter to an autostick and you do have to change the TCM and also the instrument cluster. I am working on gathering the parts but I want to make sure that I get them from an 04 or 05 as I beleive thay are compatible years, still checking on that for sure. I was curious if the shifter would just work in the normal auto mode, not utilizing the manual shift, without having the other parts installed, thank for the response.
MOPAR OR NO CAR!
My Other Rides:
Old 19 Oct 2010, 03:54 pm
So apparently your "cool vanilla" is not a GT correct?
Jerry
Old 19 Oct 2010, 10:30 pm
mopar1cjh's Avatar
Correct, it's a turbo lite but i have a stage 1 PCM for it. Just need to install it.
Wanted to try and convert the regular auto to an autostick.
MOPAR OR NO CAR!
My Other Rides:
Old 20 Oct 2010, 10:15 pm
xwing777's Avatar
Someone on ptcrew tried doing this and dont think they ever got it to work.
"Seafoam TRANS TUNE" on a automatic Transmission? RedPT07 Tech & Performance Forum 12 21 Sep 2010 11:55 am
New 08 manual trans question... pigmywolf Tech & Performance Forum 5 21 Sep 2009 08:10 pm
AUTOMATIC TRANS SERVICE RECOMENDATION:: mjb457 General PT Cruiser Discussions 7 02 Jun 2009 12:55 pm
Automatic trans sensor Dvox Tech & Performance Forum 1 25 Apr 2008 03:48 pm
GT with automatic trans and gas mileage coopj40 General Turbo Discussions 10 22 Apr 2005 04:10 pm
