2001 PT cranks but won't start
Old 18 Oct 2010, 09:23 pm
Unhappy 2001 PT cranks but won't start
Hello, I have a 2001 PT Cruiser. I recently changed the clutch and after I picked it up from the shop after about 5 miles of driving it suddenly die while shifting to 2nd gear. I tried to push start ot but would not work. It would not crank or make any noise. Tow truck jump started and it run for a minute until the charge box was disconnected. I took it back to the shop and they replaced the stater, the car now crancks but won't start. They sent me to an electric shop and they told me it was the computer(PCM), after it was changed the car is still the same, it cranck but it won't start. Somebody please help!!!!!!
Old 19 Oct 2010, 02:09 am
chigger_ns's Avatar
Default Re: 2001 PT cranks but won't start
What codes do you get? any?
2001 PT 5 speed Touring Edition
Eibach Pro Springs, Energy Suspension HyperFlex Master Kit bushings, 17" RTX Euro wheels, K&N drop in air filter, MotoMaster flat plate AGM battery, KYB GR2 shocks and struts, Booger standard shifter bushings, Ooogah horn.
Old 19 Oct 2010, 06:44 am
My hunch is the timing belt - how many miles on it?
Old 19 Oct 2010, 03:29 pm
marvinsc's Avatar
Sounds like a broken timing belt here too, did they even check that before replacing the other parts?
Old 19 Oct 2010, 10:12 pm
First it gave me P1192 P1193 and P1388 which is "Auto shutdown relay circuit problems?" Now it won't give me any codes. I check the ASD Relay and fuse and both are ok.
Old 19 Oct 2010, 10:13 pm
Timing belt seems ok, I have 145000 miles on it. The belt was changed before a 1000 mile trip from AZ to TX.
Old 19 Oct 2010, 10:17 pm
Nothing was mentioned about the belt...I took the car to PEP BOYS and the first thing they told was to change the starter to do a running diagnosis. They could not make it run so they told me it was something electrical and sent me to the electric shop where they changed the PCM.
Old 23 Oct 2010, 09:42 am
don't go to pep boy's go to a real shop it sound's like a bad cam sensor
Old 23 Oct 2010, 10:41 am
Darn. Did Pep Boys charge you for the starter and did the electrical shop charge you for the PCM? Hopefully not or your out hundred of dollars and it still won't start. If your doing the fault code check right and there's no codes, you need to get to a shop with a trusted mechanic to have it diagnosed.
Tags
cranks, pcm, won't run
Cranks but no start? C300392 Tech & Performance Forum 4 15 Apr 2016 07:58 am
Cranks but wont start master91599 Tech & Performance Forum 17 19 Dec 2011 02:58 pm
Hot start issue with 2001 Rlundstrom General PT Cruiser Discussions 1 11 Oct 2010 02:52 pm
engine cranks but wont start J_GEISLER Tech & Performance Forum 6 18 Oct 2009 08:21 pm
My 2001 PT won't start! envision_man Tech & Performance Forum 4 29 Jun 2004 08:30 am
