2001 Auto Trans Issue's
Old 19 Oct 2010, 10:30 am
Default 2001 Auto Trans Issue's
Hi everyone. I have lurked for a while but finally joined so I could get some feed back on my issue.
A couple weeks ago I noticed when put in drive it would not move.
Well I kinda assumed since it was early and I might not have been all there that I had not fully engaged drive. This has happened 3 time s in the last month. Each time I just thought It was not in drive all the way. Well this past weekend I went to go put it in Reverse , nothing. So I put it back in park then back to reverse and it went. What are some things I can trouble shoot.
The car has about 80k on it. I was thinking bout dropping the pan and changing the fluid and filter for starters. Are there any electronics that could be goobering up?
Thanks Steve
Richmond Va
Old 01 Dec 2010, 03:43 pm
Default Re: 2001 Auto Trans Issue's
Well I took the PT to a local transmission shop, and found out that Im a tool.
I never heard of checking the fluid with the vehicle running, I always thought check it after you shut it off. Well I was informed this is not the case and I was 2 qts low. I also need to get my trans solenoid replaced. That is what is leaking.
Old 01 Dec 2010, 05:43 pm
BladeRunner's Avatar
Good thing you caught it BEFORE it burned up!
Old 01 Dec 2010, 08:49 pm
garyerrol's Avatar
I was always taught to check automatic transmission fluid with engine running. Also to run the shifter through all of the various settings returning to park before checking.
2001 LE, Shale Green, Aftermarket Wheels, Shorty Antenna, AirRaid Cold Air Intake, Whelen Talons (amber/white) in front windshield, Whelen Talons (amber) in rear side windows, Tomar RECT25's (amber) and Whelen Slimlighter(amber) in back window. Kenwood TK-880H 45 Watt Mobile Radio, Antenex 3db antenna w/ NMO mount.
http://smg.photobucket.com/albums/v7...0PT%20Cruiser/
Ham: N9PTC
GMRS: WPQS324
Old 02 Dec 2010, 12:40 am
urimashe's Avatar
how do i cheak the fluid on a manual pt? do i run it or what?
2006 Base PT Manual Tranny, K&N drop in filter, Marine Blue paint, Name: Blue Monster, Body style: Path Cruizer... oh yea, seat covers? got em.
pt cruzzer auto trans OBEWON1933 Tech & Performance Forum 1 10 Sep 2010 03:17 pm
auto trans blu03gt Turbo Performance 2 26 Aug 2007 06:56 am
Auto Trans shifter quit on me.... BumperBob Tech & Performance Forum 10 30 May 2007 06:27 am
Auto trans Mr.Barton General Turbo Discussions 8 20 Sep 2004 07:53 pm
auto trans code? midnight03 Turbo Performance 1 30 Sep 2003 06:36 pm
