How much is timing belt/water pump installed by mechanic?
Old 22 Oct 2010, 04:54 pm
Default How much is timing belt/water pump installed by mechanic?
Hi
My 2003 GT Turbo now has 108k. Owners manual said to replace timing belt at 105k. I will of course have water pump replaced. Should I also have timing belt tensioner replaced? Any recommendation for a good but not expensive mechanic in NW suburbs of Chicago. I live and work in Arlington Heights. NTB quoted me $700 including parts and labor. Seems rather high.
Anybody else let me know what they paid to have installed by mechanic would be appreciated.
thanks,
Old 22 Oct 2010, 05:31 pm
Default Re: How much is timing belt/water pump installed by mechanic?
That usually runs between $800 and $1200 so you've got a good price. If I were you I'd get a second and third price quote so you won't be guessing about this.
Jerry
Old 22 Oct 2010, 06:06 pm
Rock Auto parts has a kit that has all you will need.
Old 23 Oct 2010, 02:35 am
cruserdad1976's Avatar
that is a good price the parts i would replace are the water pump---tensioners---serpentine belt---timing belt and check the motor mount
after the price of the parts you will have some anti freeze and the a/c i think will need recharged it is like $700 labor around my part of this great country
Old 23 Oct 2010, 06:14 am
marvinsc's Avatar
That is as good a price as you will find to have it done by a professional.
Old 23 Oct 2010, 06:27 pm
mdfrodolives's Avatar
Actually, the price seems a bit on the low side. I'd be a little skeptical concerning what you're going to get for $700.00. Has this mechanic worked on PT's before? There's a lot of labor involved ....
I'd love to find someone for $700.00 who really knows what he's doing to change my timing belt/water pump/all other belts/serpentine adjuster, when the time comes ....
Tim
Old 25 Oct 2010, 09:30 am
$700 from NTB (National Tire and Battery) is a division of Sears, The $700 quote only includes water pump and timing belt and labor (tax is extra). GT Turbo is used and I have no history from prior owner. Clearly I can see all other belts and hoses have been replaced. I have to assume timing belt is original and I am not willing to take a chance. The manager know set up of engine as he even had invoice for a Neon that he just changed same items. He also did recommend the tensioner as well for an extra $79. So then total bill would be $779 plus tax.
Old 25 Oct 2010, 03:53 pm
well I dont think you will beat that price any place around here
Old 02 Nov 2010, 08:41 am
Just happened to me over the weekend. Mechanic quote was $1377 and another mechanic told me that is probably without purcahse and installation of a special dealer kit that runs another $300. $1400-$1800 is absurd for a car worth 2,500 tops.
some of the posted quotes are much lower and worth considering. suggestions in sarasota area?
Old 02 Nov 2010, 11:09 am
150 miles directly north of you. Got all the parts from RockAuto Auto Parts for about $280 and the local Chrysler/Dodge dealer did the whole job for $800 labor. Only thing he found was a small leak at the crank end which needed 2 small gaskets. The area was already accessible so 1/2 more hour in labor and the cost of a couple gaskets.
Daves Log - 2002 Head Gasket/Timing Belt/Water Pump DigitaL101 Tech & Performance Forum 28 09 May 2013 02:04 am
Where to buy Timing belt/tensioner/water pump KalSaint Tech & Performance Forum 4 24 Nov 2011 09:02 am
TIMING BELT AND WATER PUMP CHANGE?? mjb457 Tech & Performance Forum 20 03 Apr 2011 10:38 pm
Changing timing belt and water pump.... missingwhatsnear Tech & Performance Forum 14 13 Dec 2010 04:22 pm
Looking for Bronx/NY Mechanic to perform Timing Belt Change djlou Northeast PT Forum 12 09 Sep 2008 03:52 pm
