ground wire on ft.struts
Old 30 Oct 2010, 01:07 am
Default ground wire on ft.struts
I had to have the lower control arm bushings replaced 3 yrs. ago at about 47000 mi. tonight I noticed that there is a wire going from the strut to the body was cut in half. I assume it is a ground wire & do I need to address this? I brlieve the dealer mech cut it when changing the bushings, no idea why Thanks Guy
Old 30 Oct 2010, 05:05 am
chigger_ns's Avatar
Default Re: ground wire on ft.struts
They relieve the static electricity that the rotating parts make I guess.
Many members say that if they are cut or missing that your wheel bearings will fail prematurely.
Yes, fix them.
2001 PT 5 speed Touring Edition
Eibach Pro Springs, Energy Suspension HyperFlex Master Kit bushings, 17" RTX Euro wheels, K&N drop in air filter, MotoMaster flat plate AGM battery, KYB GR2 shocks and struts, Booger standard shifter bushings, Ooogah horn.
There are a few posts about this. It is a ground wire that hopefully prevents the bearing from "spalling" and then you replace it. Best thing is to reattach it.
Old 18 Nov 2010, 09:04 pm
yes you need to fix it at once. i cant begin to tell you the nightmare in replacing front bearing and hub assembly. the wire is a ground that directs stray arc's of static electricity off of the bearing and hub. have you ever accidently touched a wrench across your batt. terminals. thats what it can do to the smooth surfaces in your hub. ive seen it myself, and its nasty[/U]
Old 18 Nov 2010, 10:01 pm
twress's Avatar
Guess I don't need to reply to this... lol..everyone already has the right anwsers...
ROUNDIN UP THE WAGONS 02 LIMITED WOODY, 89 CAPRICE CLASSIC
Ground wire placement? chuck2112 Tech & Performance Forum 2 01 Mar 2010 07:24 am
Ground wire elmeyer Tech & Performance Forum 2 01 Nov 2009 08:40 pm
Ground wire on hood? Hoot23 General PT Cruiser Discussions 1 15 Jul 2007 11:23 pm
Crappy Ground Wire Mean Green General Turbo Discussions 2 31 Dec 2004 09:56 pm
Ground wire on hood?? wyzard Tech & Performance Forum 2 16 Apr 2004 11:05 pm
