Fuel pump failure?
Old 30 Oct 2010, 07:09 pm
Default Fuel pump failure?
Good day.
Does anyone know the symptoms of fuel pump failure?
I ran out of gas (I think) today, and now that it's got some in the tank it won't start, and I have the check engine light on.
I know the pumps overheat and fail as gas provides cooling for them, and running with a low tank may risk overheating.
Wondering if I just cost myself a bunch of money.
Anyone have any pointers or advice?
Maybe. Maybe not.
Old 30 Oct 2010, 07:29 pm
Default Re: Fuel pump failure?
If you have the engine fault light on, you can retrieve the fault code and it will help diagnose your problem.
How to retrieve fault codes.
Old 30 Oct 2010, 07:37 pm
Thanks, Crewzin.
I abandoned it at a gas station and am at work, so will check in the morning, as I work night shift tonight.
You're awesome.
Maybe. Maybe not.
Old 30 Oct 2010, 07:41 pm
BTW, for reference, here's a list of fault codes.
Chrysler PT Cruiser computer codes
Maybe. Maybe not.
Old 30 Oct 2010, 08:04 pm
cruserdad1976's Avatar
im not sure a fuel pump will trip a code will it????
It is just never good to run a can any car low of fuel the pump is in the tank which will have to be dropped im not sure what a pump cost but its most likely way over a Benjamin
Old 30 Oct 2010, 08:46 pm
Yes a fuel pump problem could trip one of many, many codes. Among them are p0169 to p0194, p0230 to p0233, p0313, p0460 to 463, p0628 to p0629 and the most likely up to that point would be the p1172. There are probably more and more of them, but I stopped looking at that point.
Jerry
Old 31 Oct 2010, 09:34 am
thanks I should have thought there would be a code just wasn't thinking
Old 31 Oct 2010, 11:00 am
No problem, I'm the same way til i get a few cups of coffee in me.
Jerry
Old 31 Oct 2010, 01:35 pm
Still won't start.
Code is 0522, oil pressure sensor problem.
Wonder why it won't start.
At least the fix for the sensor shouldn't be too hard.
Maybe. Maybe not.
Old 31 Oct 2010, 02:23 pm
It won't start because the oil pressure switch triggered the ASD (auto shut-down relay) and it shut the car down to protect the engine. Thats what it's there for. The fuel pump going bad and a few other things that I don't recall right now will also trigger the same responce from the ASD, again to protect the engine. The ASD is in your PDC (the fuse box under the hood just in front of the master cylinder). Disconnect your neg. battery cable before doing anything in the PDC. Usually you can just remove and then replace the ASD (the old one back in) and it will reset it. Normally you don't have to buy a new one. If it was mine I would replace the fuse # 20 while you have the PDC open. It's the fuel pump/auto shut down fuse. It WILL trigger the ASD to shut your car down if a problem with the pump or fuel pressure is sensed. Its a 20 amp yellow fuse. Since you say you might have ran out of gas I would replace it just for giggles.
Jerry
Noisy Fuel Pump? BB General PT Cruiser Discussions 12 16 Sep 2017 08:36 pm
fuel pump, fuel filter or o2 sensor? Joey Tech & Performance Forum 12 02 Apr 2013 07:51 pm
fuel pump help twincruiserturbos General Turbo Discussions 10 29 Jun 2010 05:53 pm
2002 PT (in tank) Fuel Pump/ Fuel Sender cruiserich Classifieds: For Sale/Trade 0 27 Jan 2009 06:08 pm
Fuel pump nevinsrt Turbo Performance 4 15 Aug 2008 09:03 am
