Power steering problem..pls help:
Old 31 Oct 2010, 08:11 pm
Default Power steering problem..pls help:
Hi all..This is my first thread on this forum and it is unfortunate it is regarding a problem that has developed on my 2006 pt cruiser. It was running just fine till today afternoon.I parked the car and a short time later when i turned it on..the steering would not move one bit..No lights are coming up on the instrument panel..i tried to reverse the car and then drive it forward ,still no change.. its too hard to even move it a little bit.. i checked the power steering fluid ,though i do see some fluid in it, the lid just has marking of hot/cold on it and no gauze to actually tell if the levels are low. If some one ever had a similar problem ,pls suggest what might be the problem. And please please tell me its not going to be a costly affair!!!! The car is not under any warranty. Pls reply at the earliest. Thanks and god bless.
Old 01 Nov 2010, 01:50 am
mdfrodolives's Avatar
Default Re: Power steering problem..pls help:
Let me get this right? The steering wheel doesn't move even a tiny bit?
If so, it's not a power steering problem. It sounds like your steering wheel has somehow locked up? Even with the power steering busted, you should be able to move the steering wheel (it's not very easy--but it should move).
Tim
Old 01 Nov 2010, 10:07 am
HI mdfrodo..thanks for the reply..my fault..let me correct myself..it does move,but just a little bit..just a few degrees and it takes a LOT of power to get it to turn at a corner...sorry about my previous message not being too specific.thanks again.
Old 01 Nov 2010, 11:31 am
Broken belt!!!!
Old 01 Nov 2010, 12:25 pm
The power steering pump failure will not give a fault code. There's been several pump failures (mine included) that happened all at once while driving making it almost impossible to steer and no failure light.
Old 01 Nov 2010, 03:29 pm
I just encountered an intermittent problem with the power steering on my 2001 PT. They tried a new belt and flushing the power steering fluid. This did not fix the problem. The mechanic found a service bulletin that referenced a problem with the screen filter in the power steering reservoir getting clogged and causing the power steering to stop working. The screen filter is built into the reservior so they had to replaced the power steering reservoir for $196.00. This was done 3 days ago and seems to have fixed the problem.
Old 01 Nov 2010, 05:31 pm
Look at the suggestions given above. And still, I'm a bit confused. You say you can only turn the wheel a few degrees. If so, how do you manage to turn a corner with just a "few" degrees turning radius?
I'll assume that if you can turn a corner (with a lot of effort) then you have more than a few degrees. That said, the suggestions given by the above posters should get you going in the right direction.
Check the belt, the fluid level. Maybe you have a clogged screen like the above poster mentioned. If you can turn enough to go round a corner--but with a lot of effort--then I'd have the car towed to a mechanic who can fix it for you. It does, in fact, sound like the power steering system. Crewzin has spoken previously about losing his power steering while going round a corner, and the story is not a "reasonably safe driving" story. So--get the car towed--and fixed.
Tim
Old 03 Nov 2010, 12:17 pm
The one thing that seems off on my 06 is that when it's cold, the power steering is "growly", reminds me of later 80's Ford noisy ps systems. Once the car warms up, it's fine. -Adam
Born to tinker! 06 PT, 1964 Jeep J 300, 70 Suburban, 56 Corvette (Schwinn) 59 Wasp (Schwinn)
Old 03 Nov 2010, 06:55 pm
VNT's Avatar
VNT VNT is offline
That is why I freshen the PS Fluid up a couple times a year, in the case of the PT which takes ATf, synthetic ATF will help prevent issues.
How many people bother to either change the fluid or suction some out of the reservoir a couple times a year to keep it cleaner and replenish the additives?
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 08 Nov 2010, 09:18 pm
BladeRunner's Avatar
I had a similar problem with my 01 Grand Caravan, the steering didn't stop working,but, at parking lot speeds the steering would "shutter"...it turned out to be that filter in the power steering reservous. I replaced it with a new one $38.00 and it has been fine since about a yr ago.
Power Steering Problem - Funny but True... sifu_scott General PT Cruiser Discussions 17 19 Mar 2011 10:24 pm
Possible Power Steering Problem ptbeard Tech & Performance Forum 6 20 Nov 2010 09:06 pm
PT Power steering problem RandySC Tech & Performance Forum 4 01 Jul 2010 11:06 am
Yet another Power Steering problem fritz_t_coyote Tech & Performance Forum 3 23 Nov 2005 04:28 pm
I think I'm having a power steering problem! lumofny Tech & Performance Forum 5 18 Jan 2005 01:12 pm
