Syncros might be going bad, low on tranny fluid or the fluid is nolonger doing the business. Change the tranny fluid and see if there is any difference.
![]() 2005 Touring Black - Automagic....California Smog Legal ![]() H&R Cup Kit | TSW Sakata 18x8 35ET | Nankang NS-II 235/40/18 | SPC front alignment cam - rear shim | Master Pro Rotors | Master Pro Ceramic F/R pads | Rebuilt Cylinder Head - Safety Valves and Guides | Felpro Head Gasket and upper rebuild kit | Fail-safe 195 degree thermostat | Mopar Waterpump...lol | 3rd radiator fan motor | Gates timing belt kit | WIX filters (oil, transmission) | Mobile 1 5w30 | Mopar ATF4 | Redline Water Wetter | K&N Drop-In | 4th Drive side Axle | Energy Suspension Torque Mounts | 3rd set of Torque Mounts... ![]() |
I'll take a look at it thanks for the suggestion.
I've noted however that I DO can enter into the gear, it just requires more force to get into. In fact at times I can not get into gear, and at other times it goes really easy, almost as if sometimes the gears don't slide into each other... I also notice that when driving in 2nd, and 4th gear, while driving I can feel the gearstick vibrating, as if I could feel the gears rotating and gripping into each other (I only feel this when pulling the stick backwards). I don't have that in 1st, 3rd and 5th gear (which are all gears selectable by moving the gearstick forward). Since I never had a manual transmission before, I was a bit afraid of 'yanking' the stick (though within operating limits). Oil can be an issue, since it has nearly 100k miles on it, and I don't know when the last oil change has been done. What's more, recently the 'garage man' saw some oil drips on the bottom of the car, but it did not seem to be coming from the engine, as the engine oil levels all stayed at max levels. I may indeed need to take a look at it... I have yet to find the tranny's dipstick. |
Tags |
gear, gearlock, issues, locking, switching |
Thread Tools | |
Display Modes | |
what is wrong with my manual transmission? | BrianW | General PT Cruiser Discussions | 52 | 20 Jun 2016 10:27 pm |
Best PT Manual/Transmission Flush | ptbeard | General PT Cruiser Discussions | 7 | 21 Feb 2009 08:31 am |
Manual transmission | 1gr8rubaz | Tech & Performance Forum | 0 | 05 Oct 2007 11:22 am |
Manual Transmission Parts? where to buy... | runtime | Tech & Performance Forum | 3 | 26 Apr 2007 07:24 pm |
5-Speed Manual Transmission | thegoldpt | General PT Cruiser Discussions | 21 | 04 Aug 2005 10:18 pm |
