P2074-manifold Pressure/throttle Position Correlation
CORRELATION - HIGH FLOW/VACUUM LEAK When Monitored: Engine Running, during all drive modes. Set Condition: If vacuum drops below 1.5 Hg with engine RPM greater than 2000 RPM at closed throttle. POSSIBLE CAUSES VACUUM LEAK HIGH RESISTANCE IN MAP (K7) 5 VOLT SUPPLY CIRCUIT RESISTANCE TO GROUND IN MAP (K7) 5 VOLT SUPPLY CIRCUIT MAP SENSOR HIGH RESISTANCE IN (K1) MAP SIGNAL CIRCUIT RESISTANCE TO GROUND IN (K1) MAP SIGNAL CIRCUIT HIGH RESISTANCE IN (K4) MAP GROUND CIRCUIT PCM TP SENSOR OPERATION HIGH RESISTANCE IN (K6) TP SENSOR 5 VOLT SUPPLY CIRCUIT RESISTANCE TO GROUND IN (K6) TP SENSOR 5 VOLT SUPPLY CIRCUIT TP SENSOR HIGH RESISTANCE IN (K22) TP SIGNAL CIRCUIT RESISTANCE TO GROUND IN (K22) TP SENSOR SIGNAL CIRCUIT HIGH RESISTANCE IN TP (K4) SENSOR GROUND CIRCUIT |
I just google the codes that I can't find any other way. To find 2074 for instance I would google "auto trouble code 2074"
Jerry |
To get your answer, I Googled "PT Cruiser Fault P2074"
CREWZIN
provide you with all the information you need now is time for you go and look in the engine compartment intercoler tubes damage and cust on the plastic tube hoses and intake check them all VACUUM LEAK HIGH RESISTANCE IN MAP (K7) 5 VOLT SUPPLY CIRCUIT RESISTANCE TO GROUND IN MAP (K7) 5 VOLT SUPPLY CIRCUIT MAP SENSOR HIGH RESISTANCE IN (K1) MAP SIGNAL CIRCUIT RESISTANCE TO GROUND IN (K1) MAP SIGNAL CIRCUIT HIGH RESISTANCE IN (K4) MAP GROUND CIRCUIT PCM TP SENSOR OPERATION HIGH RESISTANCE IN (K6) TP SENSOR 5 VOLT SUPPLY CIRCUIT RESISTANCE TO GROUND IN (K6) TP SENSOR 5 VOLT SUPPLY CIRCUIT TP SENSOR HIGH RESISTANCE IN (K22) TP SIGNAL CIRCUIT RESISTANCE TO GROUND IN (K22) TP SENSOR SIGNAL CIRCUIT HIGH RESISTANCE IN TP (K4) SENSOR GROUND CIRCUIT
2008 Pt cruiser Touring 2004 Pt Cruiser GT 2004 Chrysler 300M 2008 Chrysler Pacifica awd |
This happened to us today, what was the outcome and can I drive the car in the meantime?
Thread Tools | |
Display Modes | |
ERROR CODE P2074 | spinner | Tech & Performance Forum | 5 | 30 Jul 2016 06:00 pm |
Code ? | 1lowufo | Tech & Performance Forum | 1 | 25 May 2010 06:25 pm |
shaking today stepping on gas p2074 + p0122 | PTC06Peet | General PT Cruiser Discussions | 2 | 22 May 2009 06:07 am |
344 code | jkinard73 | Southeast PT Forum | 2 | 08 Apr 2009 12:54 pm |
what is this code | medtwo | Tech & Performance Forum | 2 | 04 Dec 2008 07:54 am |
