L. Headlight low beam not working
Old 09 Nov 2010, 09:58 pm
ProDigit's Avatar
Default L. Headlight low beam not working
I tested the bulb, seems ok,
Tested the wire, the ground seems ok, the positive connection seems interrupted on the Left headlight.
All other lights, and electric stuff on the car seem to work fine.
I found a wiring diagram, but don't really understand it.
Since it seems that the left low beam bulb is connected to the L city lights, and blinkers, it seems that the fuse is still ok.
But I can't be sure because I see bare wires running across the battery, as if someone had been messing with them... (prev owner); although the wires he connected where towards the FAN, to keep it always on, not the lights...
I could run a lead from the Right headlight to the left, underneath the bumper; or just tap a line off the fan.
any other (more professional) solutions (eg: renew or check the wire to the right fuse, whichever it could be)?
wiring diagram (sorry for the bad tile, click on it to zoom):
Old 10 Nov 2010, 05:32 am
Default Re: L. Headlight low beam not working
Tested good or not, replace the bulb. If it doesn't work, you have a spare.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 11 Nov 2010, 12:27 am
ProDigit's Avatar
I have a spare, and tested the bulb.
It's the cable (the + is interrupted).
Better light bulbs low beam? ProDigit General PT Cruiser Discussions 12 03 Oct 2011 01:35 pm
Headlight mod... CYCLONE_06 Exterior & Interior Styling 20 11 Mar 2011 02:56 am
One headlight not working 06girl General PT Cruiser Discussions 4 10 Sep 2010 08:54 pm
Headlight ty97206 Exterior Accessories Forum 1 24 Sep 2007 03:18 pm
