Crank Sensor
Old 10 Nov 2010, 03:52 pm
ejstith's Avatar
Default Crank Sensor
Well it wasn't long ago that I replaced the crank position sensor. Now I have a light again and says a P340 cam position sensor. I had been noticing a smell inside like an exhaust leak and finally the light came on and it ran bad. Well today as I was checking out the sensor I noticed my oil install cap was off. I found it buried down in the motor and put it back on. I think that fixed the smell inside the car but I wonder if it could have anything to do with the cam position sensor light coming on? I don't see how but with these electric cars I'm not sure of anything. I went and got a new sensor today but I haven't put it on yet. I just took it for a ride and it runs fine now but it did that with the crank position sensor too, fine one time and not the next. I have a Car Chip OBII reader and it just will not sense trouble codes on the PT. Will on everything else I own but not it. It will log the miles, mph etc but not trouble codes and will not turn out the engine light .. I guess I'll replace the sensor just to make sure. ... I mean it's not that expensive ..
2005 PT, Limited turbo Lite. Automatic all whistles and bells.
Old 10 Nov 2010, 06:49 pm
Default Re: Crank Sensor
Before replacing it, take off the negative battery cable for 5 minutes. That should clear the fault code from the computer. Then drive it to see if the light comes on again. If it does, then replace the sensor.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 10 Nov 2010, 07:12 pm
BladeRunner's Avatar
Lightbulb Re: Crank Sensor
I'm still finding my way around my PT that I got about 3 wks ago. I have a "bit" of a problem and wonder if it may be the crank sensor? At a steady speed with the cruise set, now and then the engine seems to "surge" a bit; I "had" a small hesitation off idle,but, that cleared up after a can of Sea Foam. it has 205,000 KM on the clock. Other than that it seems to run fine.. with lots of power.
Old 11 Nov 2010, 02:41 pm
ejstith's Avatar
I just went ahead & changed it Cruiser. No more than it cost it was probably about due anyway since I already did the crank sensor the other day. Done deal..
crank shaft positioning sensor?? help! xodeflepgirlox Tech & Performance Forum 3 08 Oct 2010 07:41 pm
Won't crank sometimes! RodF763 Tech & Performance Forum 8 09 Sep 2010 12:31 pm
Code 1391 Sometimes I can't see the crank or cam sensor signal CandaceMoore Tech & Performance Forum 8 29 Jul 2010 08:06 pm
Cam Sensor code changed sensor still dead RottenKid Tech & Performance Forum 8 18 Nov 2008 08:17 am
