Knocking in front end.
Old 23 Nov 2010, 01:44 pm
Red face Knocking in front end.
Have a knocking sound developing in the front end of my 2005 HO PT Cruiser Convertable. Not the sound one would look toward the front end being out of alignment (tires have no unusual wear) or one coming from the engine. Almost the sound as if it was coming from one of the drive shafts yet neither have any play in them that I can tell. It has over 169,000 miles. Any idea what it could be?
Old 25 Nov 2010, 12:24 pm
Matt42's Avatar
Default Re: Knocking in front end.
Describe the conditions where you hear it. Hitting a bump? Turning left? Turning right? Accelerating? Stopping? Slowing? All the time? Running over armadillos but not opossums?
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
Old 25 Nov 2010, 12:46 pm
Did you take a good look at the bushing around the front end? At that kind of mileage,if you haven't already changed them, they are sure to have excessive wear. I just found a couple of mine in need of replacement at 106K. Small knocking sound starting up.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 25 Nov 2010, 08:00 pm
Matt42's Avatar
No doubt about it. Bad bushings will make that noise even when running over a mouse.
Old 26 Nov 2010, 07:07 am
golf55555's Avatar
I would start at the control arm bushings... Move the wheels to the left and look at the vertical bushing on the pass side control arm.... I suspect what you will find is the control arm laying on the frame and the bushing torn. Do the same but opposite for the drivers side. You can replace the whole control arm both sides including the ball joint for about 125 on ebay shipped. Several brands and sellers....Just pay close attention to the price and shipping. I just got a set for 98 shipped. While you're at it, get a set of front Sway bar link bushings.. they have to come off to replace the control arm so might as well do it now. About 13 ea side. Also buy a set of front sway bar bushings, they are about 20. BE VERY CAREFUL when removing the 4 bolts holding on the sway bar... they will be rusted and easily broken. Spray them down with PB blaster a few days before. Then....TAKE YOUR TIME... They will break!
Hope this helps!
KNOCKING ON FRONT PASSENGER SIDE SUSSPENSION PATGAS Wheels, Tires, Suspension 2 11 Oct 2009 12:48 am
knocking noise from rear Megalon Wheels, Tires, Suspension 5 13 Jan 2008 09:44 am
"I hear you knocking, but you can't come in" zzzhuh General PT Cruiser Discussions 20 22 Feb 2005 11:40 pm
knocking sound mykelzy Wheels, Tires, Suspension 6 23 Sep 2004 09:51 am
knocking problem Jimbo Wheels, Tires, Suspension 11 14 Mar 2004 01:36 am
