Front End Shake
Old 04 Dec 2010, 04:16 pm
Default Front End Shake
Why would my front end skake? I had a alignment and it was a lot better but it did not last long. The rims are not bent. checked that myself.
Old 04 Dec 2010, 07:36 pm
BladeRunner's Avatar
Default Re: Front End Shake
What speed does this happen? Is it only when you apply the brakes? Does it happen all the time? Need a bit more info.
Old 05 Dec 2010, 12:40 pm
Under inflated tires will cause a shake. The stock Goodyear tires that PT's come with are crap and will shake. When my 02' was new I had that problem but it went away as soon as I went to premium tires. I recently bought a 2009 that still has the factory Goodyear tires on it and have the same shaking problem as the 02'. Still too much tread left to change them out so I'll will live with it for a while.
Old 05 Dec 2010, 06:17 pm
It starts to kick in at around 5mph and the faster you go the worse it gets. The brakes have no effect. You can really feel it in the steering wheel at highway speed.
Old 05 Dec 2010, 06:29 pm
Well, you said you checked the wheels and they are not bent? It sure sounds like at least one IS bent; The only other thing I can think of, this actually happened on a car I had, the steel belts "twisted" right in the tire, after a few wks the other 3 tires did the same thing...turns out there was a run of bad tires, this was a long time ago,but, it was just as you describe. If you can, jack up one wheel at a time and spin the wheel, watch the tread..see if it goes off center.
Old 05 Dec 2010, 08:29 pm
SCBluePT's Avatar
It could be as simple as the tires/wheels needing to be balanced.This will cause your steering wheel to shake.
Old 06 Dec 2010, 04:31 pm
It's possible,but, that usually doesn't happen @ 5 mph It almost sounds more like a wobble if it's happening at that speed.
Old 06 Dec 2010, 08:47 pm
I have the samthing I replaced the driveaxles it fixed 90% of it...I think it was bad for a while and has losein up somthing else...get turbo axles
Front wheels shake at speed 50+ mph bigger_hammer Wheels, Tires, Suspension 5 26 Aug 2010 04:00 pm
Front end shake THANKS tony General PT Cruiser Discussions 5 08 Feb 2003 02:39 am
Front end shake tony General PT Cruiser Discussions 8 04 Feb 2003 10:59 pm
2002 Crusier Front end shake American flyer Tech & Performance Forum 3 09 Oct 2002 03:26 am
