Starting Issues Need Help!! 01 PT Manual
Old 07 Dec 2010, 10:56 am
Exclamation Starting Issues Need Help!! 01 PT Manual
Hey everyone,
I have an issue that has me stumped. I have been having trouble getting my Pt Cruiser to turn over. I have 2 starters, one is on the car. I have had both of them tested at 3 different places and they all said they were fine. I have replaced the battery 2 times, last time was yesterday and it's testing great. All lights, etc. work fine with no dimming. The ignition switch and starter relay are both new as well. Every time I try to start the car, it just "clicks" and won't turn over. I checked the wires for the crank sensor and they looked fine.
The car will start and run fine if I push start it. The only error code I get is that the battery has been disconnected in the last 50 starts however, the check engine light stays on with no other codes.
I am really confused and I have an appointment with an electric shop on Thursday but would really love to solve the issue myself because as we know, I won't have any money left after taking it there!
Please, any help and suggestions would be greatly appreciated!!!!
Steven
Old 07 Dec 2010, 12:22 pm
Default Re: Starting Issues Need Help!! 01 PT Manual
Basics -
Battery cable connections clean and tight?
starter cable connections clean and tight?
Condtion of the cables? - including to ground from Battery.
That's where I'd focus.
Old 07 Dec 2010, 12:23 pm
I was thinking either that cable from the starter to batter or the solenoid. But everyone says that the solenoid and starter come as a unit.
Steven
Old 10 Dec 2010, 07:22 pm
BladeRunner's Avatar
Neutral start switch not adjusted correctly? If the manual even has one? I'm not familiar with the manual.
Old 07 Jan 2011, 09:49 am
ilrglen's Avatar
I've had a starting problem with my '01 for 2 years now and the dealer has not been very helpful. Replaced the battery and still no change. The last time I took it in the dealer did notice that the starter is dieing so I replaced that and while the starter works wonderfully now the problem came back. I thought it was may battery connectors because they would get full of corrosion and every time I fiddled with them (I replaced them 4 times) the problem would magically disappear for a month or two.
The other day I thought it might have something to do with the ground strap from the battery so I replaced that with a nice heavy braided one ($7) and everything works superbly now. Even the horn got louder which I thought was next on my list of things to replace. I think my problem is solved.
I would highly recommend that if you are having ANY starting issues that this be the first thing to replace since it is a cheap ($7) and quick (5 minutes) job which could save you a lot of guessing.
Glen Kohut, Manager
International Lamborghini Registry
http://www.lamborghiniregistry.com
Old 07 Jan 2011, 12:52 pm
themadgreek187's Avatar
u can try the battery cables but here is my reply in another part of the forums
"ok back ITT and happy new yr everyone. i finally figured out my starting issue. the wires going into the PCM box must have a short in it somewhere. if i move those around when it won't start, it will fire right up. my uncle found this while i was for christmas. been working fine since then. "
Old 07 Jan 2011, 03:25 pm
So to the op.
Does it just not START or does it not CRANK
They are two different things, which is not happening?
Old 07 Jan 2011, 03:41 pm
if you read his last post, he says he solved his starting problems by replacing his ground strap.
Old 31 Jan 2011, 03:19 am
mnahmnah's Avatar
The original poster didn't say he solved it, those are other user's comments on what worked for them... I got some good ideas for my problems from them, though, thanks guys! (I'm not the original poster, either. Hope he fixed it?)
2002 Pt cruiser starting issues ort102 Tech & Performance Forum 5 11 Jul 2011 07:28 pm
Manual Transmission issues 2005 PT Touring azptowner Tech & Performance Forum 4 14 Oct 2010 02:42 pm
2006 PT starting issues thebriarman Tech & Performance Forum 5 25 Jul 2010 10:13 pm
Jump Starting Issues myptc Tech & Performance Forum 3 22 Mar 2010 04:52 pm
2008 PT Starting Issues PTcruisinator Tech & Performance Forum 2 14 Jan 2010 08:25 pm
