Transmission leak above oil pan
Old 11 Dec 2010, 10:07 am
Default Transmission leak above oil pan
I will try to post a photo, but i seem to be losing fluid from above the transmission pan towards the front of the car .
when i look at it from under the car, there is a some kind of housing parallel to the radiator right above the pan. i can actually see fluid seeping out from the sandwichwed parts of the housing.
any idea what this part is called?
Old 11 Dec 2010, 10:57 am
Default PHOTO of Transmission leak above trasmission fluid pan
Anyone know if this is a "difficult job"? I guess i'll have to remove the radiator. Can the gaskets be redone? What is this part called?
THANKS!
Old 19 Dec 2010, 10:11 pm
RedPT07's Avatar
Default Re: Transmission leak above oil pan
Check here on PT CREW how to change Solenoid Pack
Old 21 Dec 2010, 12:17 am
mdfrodolives's Avatar
Check Red's post. Sounds like your solenoid pack's gasket. Mine leaks, too, but only in the summer. I nap a lot in the summer, so I just haven't gotten around to fixing it, yet.
You don't have to remove the radiator; but you do have to remove the battery and battery tray. Supposedly you can now purchase just the solenoid pack gasket--and not the whole solenoid and gasket. If so, you'll save a lot of money. However, in the manual they tell you to "Perform Quick-Learn Procedure" when you're done with changing the gasket--or solenoid pack/gasket. So you if you do the job, let me know if you really had to take the car to the dealer for the Quick Learn.
Tim
Old 21 Dec 2010, 09:21 am
RedPT07's Avatar
When I change my transmission fluid the first time I thought I need to do the Relearn process and I found on internet the procedure with out going to the dealer. Check this Link.
transmission fluid leak joeus Tech & Performance Forum 11 11 Jul 2013 09:18 am
Transmission leak Encara2 Tech & Performance Forum 6 01 Feb 2013 07:15 pm
Transmission solenoid leak imalittleturt Tech & Performance Forum 15 29 Dec 2010 08:47 pm
Transmission leak!!! Milowe General PT Cruiser Discussions 1 17 Jun 2008 03:44 pm
Transmission leak macster Turbo Performance 17 25 Jan 2004 05:38 pm
