Code 340
Old 11 Dec 2010, 06:14 pm
Default Code 340
Please help!! Replaced camshaft and crankshaft sensors, car still wont start
Old 11 Dec 2010, 06:29 pm
WolfmanG's Avatar
Default Re: Code 340
What does it do when you try to start it? does it at least turn on? Is it no cranking over?
-Danny Wolfman G
Old 11 Dec 2010, 07:07 pm
Shelly, welcome to the Forum. May I ask how you determined that you needed the sensors? Did you do the key dance? Also, did you use Chrysler sensors, as our PT's do not like aftermarket sensors.
Old 12 Dec 2010, 03:32 pm
It turnsover like it wants to start but wont. The code reader said it was the camshaft postion sensor
Old 12 Dec 2010, 03:58 pm
As Hooligan asked, did you use a genuine Chrysler Part or a sensor from an auto store? Some (or most) after market sensors either don't work at all or not for very long. There's also cases (including mine) that the wiring harness (which runs from the sensor along the back of the engine rubbed against something that chaffed the harness and broke of the wires inside the casing.
Old 12 Dec 2010, 04:14 pm
Also did you reset your computer after replacing the sensor? As in pull the negative lead for 5 minutes, then reconnect.
Old 12 Dec 2010, 04:44 pm
yes my husband done all of that and found crack on edge by screw housing in new camshaft sensor. would that stop it from starting? also he says codes p0522 and p0340 show up on dash, why is that?
Old 12 Dec 2010, 04:45 pm
I think he did, the auto store looked it up said thats one we needed. not to sound to dumb but would it say Chrysler on the box it came in lol
Old 12 Dec 2010, 04:49 pm
yes it turns on but sounds like it wants to start and that whats so frustrating. idk what to do anymore over something so simple
Old 12 Dec 2010, 05:02 pm
A small crack on the sensor shouldn't hurt but if it's a new sensor from Chrysler. I'd take it back, unless your husband put too much pressure on the screw while tightening it down and broke it himself.
No this will sound odd and it's not supped to work like this (I think) but a few owners have told the same story about the engine stalling with a P0522 code (oil pressure sensor low) and I stopped one day while on patrol and two elderly ladies with a PT were stalled at the traffic light. Kept turning over the engine and it wouldn't start. Told her how to do the key trick and sure enough it was the P0522. Knew what it mean but didn't make since. That code should stop the car from starting. Got her a tow to the nearest Chrysler dealer, they couldn't find anything wrong but changed the oil sensor anyway (like any good dealer trying to make money) but sure enough, the car started up and ran fine. Maybe there's some sort of fail safe that if the computer sees a low oil pressure fault from the sensor, it wont' let the engine start.
Haven't done it, but supposedly not too bad of a job to replace that sensor.
AND, after reading what yo said, you didn't get a Chrysler sensor. It probably says "Made In China/Singapore/Malaysia/Whatever" on the box.
CEL code help?? 05pt Tech & Performance Forum 11 08 Sep 2010 10:51 am
code 352 coco1476 Tech & Performance Forum 5 18 Jan 2010 05:19 pm
Code 320. 300 brklnnite718 Tech & Performance Forum 6 16 Jul 2009 08:34 am
what is this code medtwo Tech & Performance Forum 2 04 Dec 2008 07:54 am
Code Help! 1lowufo Tech & Performance Forum 1 21 Aug 2004 07:03 pm
