Need help with radiator replacement
Old 11 Dec 2010, 11:17 pm
Default Need help with radiator replacement
Working on 2008 PT Cruiser, new radiator has 2 inlets on bottom tank that old radiator didnt have. Part number is right for non turbo. The old radiator has ac condensor and transmission cooler bolted to the radiator. Are the two inlets at bottom for a built in transmission cooler? Not sure. Filled radiator and did not cover those two inlets and no water leeks out?
Old 12 Dec 2010, 08:24 am
Default Re: Need help with radiator replacement
Maybe this can help. 01-03 Haynes Manual.
Old 12 Dec 2010, 12:51 pm
Matt42's Avatar
Wild guess: Yours is a 5 speed. Right?
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
Old 07 Mar 2012, 08:55 pm
crazyptguy's Avatar
no automatic i just bought a new radiator and have the same problem part numbers are right but these two brass nipples arent on the old radiator . is this a built in trans cooler and if it is which way do the lines hook up ,
Old 07 Mar 2012, 10:02 pm
Power steering cooler. Trans cooler is external.
Direction determined by hose routing only.
Old 07 Mar 2012, 10:08 pm
crazyptguy's Avatar
ok so being i dont have a ps cooler i just dont use these right? kind like tits on a tomcat not needed
Old 07 Mar 2012, 10:26 pm
I thought that was on a bore hog? lol If nothing was connected before don't have to now. Just plug them to keep junk out. Plastic , metal or whatever.
Old 07 Mar 2012, 10:30 pm
crazyptguy's Avatar
thank you
Old 07 Mar 2012, 11:04 pm
thank you
You'r are most welcome!
Old 08 Mar 2012, 01:24 am
Suggestion:
Buy a small cooler, plumb it to the PS , These little 4 bangers put out a lot of heat right next to the PS rack, wouldn't hurt
poll: radiator fan replacement bugatti Tech & Performance Forum 50 06 Oct 2013 07:55 pm
Radiator replacement aword Wheels, Tires, Suspension 1 05 Sep 2013 07:02 pm
2006 Radiator replacement Samson Tech & Performance Forum 10 06 Nov 2010 09:19 pm
Help! Need replacement radiator. Who to buy from? RobertKemp Classifieds: Want To Buy 0 19 Oct 2010 05:15 pm
replacement radiator sandylolee Turbo Performance 1 05 Jul 2009 01:23 am
