ABS sensor problem
Old 12 Dec 2010, 11:58 am
chuckd1991's Avatar
Default ABS sensor problem
My ABS and traction control lights are on. Apparently one of the ABS sensors isn't working. It looks like an easy fix (if it is the sensor), but I need to find out which one it is. Should I go to the dealership or another shop and have them scan it?
Old 13 Dec 2010, 09:17 am
Taggert_LOA's Avatar
Send a message via AIM to Taggert_LOA
Default Re: ABS sensor problem
shop or dealer is going to charge you 100.00 to do the test and then rape you on price and install of the sensor. you can rent a abs scan tool (get your money back when you return the tool) find out what sensor you need and change it yourself. all it is a plug and nut.
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
Cam Shaft sensor problem lokiloki Tech & Performance Forum 10 28 Aug 2013 10:27 pm
Another overheating/fan or sensor problem! Yay? Faerie_Speak Tech & Performance Forum 19 12 Aug 2010 06:13 pm
More money$$$Cam sensor problem careyk General PT Cruiser Discussions 5 07 Jun 2010 10:44 pm
Problem w/ GT Oil sensor?? sakigt General Turbo Discussions 22 31 Jan 2004 10:47 am
problem with catality &sensor ë antonio Tech & Performance Forum 1 13 May 2003 04:43 pm
